Possible bad battery?
Old Dec 2, 2003 | 07:01 PM
cruzersi99's Avatar
Default Possible bad battery?
My Eclipse HU has been acting up. Every once and a while it would reset itself to defualt settings.
I thought that it was a bad ground or connection, and after a little searching I found somethings that may have caused it to trip out. It was fine for about a week.
Today when I got gas, I left the lights and stereo on and when I went to start my car the stereo reset itself again. At this point I'm thinking that maybe the headlights and the stereo running for 5 min. may have drained the battery enough to reset the stereo upon start up?
Is the battery dying?
I did the same thing when i got home, with the same result. The stereo works fine, and only resets after I restart the car (After leaving the lights and stereo on).
Old Dec 2, 2003 | 08:16 PM
vigor5spd's Avatar
Default Re: Possible bad battery? (cruzersi00)
Check your 12V source wire to your headunit and see if there is any power.
It seems you blew a fuse.
Old Dec 2, 2003 | 09:34 PM
cruzersi99's Avatar
Default Re: Possible bad battery? (vigor5spd)
If the fuse blew wouldn't it not work at all?
toner297
Honda Civic (2001 - 2005)
12
May 24, 2011 12:39 AM
ludachrisvt
Sep 22, 2008 11:01 AM
Tip14
Dec 27, 2007 01:13 PM
R-81DC2
Jun 5, 2007 09:21 AM
c for sea
21
Aug 12, 2005 06:38 PM
