question about using a GSR head w/dome pistons
well heres the thing,
im planning on getting a GSR portflow head and putting on a LS/vtec block with some ITR pistons.
is using the GSR head okay with dome pistons???
i hear different things such as the GSRs valves are seated differently from a b16 head, so the dome pistons may smash the valves. and i hear that its okay to run this setup.
i wanna know what you guys think, if this setup would work or not.
thanks
thanks
use c-speed calculator - i wanna tell you it will be ok, because the combustion chamber of the gsr is up more - so like putting a gsr head on a type r block works and equals less compression of a itr, but more than a gsr, not sure with ls rods though.
itr rods and gsr rods teh same length i thought.
ls rods are weak, spend the extra 100 bux to get some gsr rods and have them balanced then put some arp bolts on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob-DC2 »</TD></TR><TR><TD CLASS="quote">itr rods and gsr rods teh same length i thought.
ITR rods and GSR rods are the same length. Same stroke-87.2mm.
LS rods are shorter. You have to use LS rods with an 89mm LS crank. But ARP rod bolts on the LS rods is a smart move.
i say you run the beeatch with some ctr pistons, mill the head and run a mugen 1 ply. it should run fine...........haha! using ls rods in a gsr block require you to modify the oil squirters inside the block. running that head on that block should give you no problems unless you run something higher than a ctr piston. hope this helps..........peace!
I ran a GSR head on a stock ITR block with no problems. GSR head will give you a little more compression than a b16 head. I also ran a GSR head on my last motor with 11.5:1 Wiseco pistons, and had no problems.
Good Luck
Good Luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chemicalviper »</TD></TR><TR><TD CLASS="quote">use c-speed calculator - i wanna tell you it will be ok, because the combustion chamber of the gsr is up more - so like putting a gsr head on a type r block works and equals less compression of a itr, but more than a gsr, not sure with ls rods though.</TD></TR></TABLE>
i am pretty sure its the other way around, the gsr combustion chamber is smaller then the pr3 head so compression will increase with a gsr head.
mymeatb18"
Jun 26, 2006 03:16 PM
xDicktonesx
Nov 21, 2005 07:36 AM
