Speed sensor?
Well... While driving my 90 ex with f22a6, I noticed that after a few minutes the Sports light would begin to flash and the speedometer would not work. This doesnt happen immediately when i drive... It just comes out of nowhere and goes away sometimes then comes back. Any ideas?
Mine did the same thing, I just took mine to honda and said I would like the speed sensor replaced, also if you want to make sure its that check your ecu, it should be throwing a code, I think its 13 or 17.....but its been a while. Mine is a 4th gen, went out at about 110K (not bad). You could also look in a chiltons or search on how to replace your speed sensor, I want to say its (and don't quote me on this) behind the engine by the rear engine mount. And when mine went out, when it was cold it would show the speed fine after warming up it would either spike to like 100mph (kinda cool to see) and then go to 0 then the sports light would flash.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRDrvr »</TD></TR><TR><TD CLASS="quote"> also if you want to make sure its that check your ecu, it should be throwing a code, I think its 13 or 17.....but its been a while. </TD></TR></TABLE>
17
17
