check engine light and atts light 2000 prelude
I had skunk2 cam gears and an apex-i vafc instally by a local reputable shop. In the process 14 valves were bent and a three day process turned into three months . It has now been five months and the lights are still on. The code came up 1259, which is vtec malfunction ,but the vtec still engages. I was wondering if anyone else has encountered this problem. Other modifications are pulleys, intake, exhaust, MSD, and other things that don't realy affect this issue. I would greatly appreciate any help.
when my brother bent some valves on his 2001 lude he also had the check engine light and ATTS light on even though the valves had been replaced, but the thing was his car would vibrate at idle until he took into the honda dealer and found out his timeing was off.
the shop said that the timing marks were wrong on the aftermarket cam gears, but I don't believe them. I plan on taking the car to my dealer, but they are a little iffy about working on it since I have some mods. I'll check into the timing and see what happens.
does your car vibrate at idle? I believe my brother got misfires across all cylinders and he too could engage VTEC even though his check engine light was on. I'm not too sure on the cam gear thing, but did they tune the cam gears on the dyno or when they installed them they just left the timing marks off from 0 degrees?
My car seems to run fine. There are no idle problems, and I believe there has been a gain in power. 176whp 160tq on the dynojet. Assuming I had around 80% - 85% of the advertised 200 crank horsepower, that is a 10 - 15 hp increase. The main concern is the unknown problem that may be serious. Are these numbers accurate and would this problem seem to be more electrical or mechanical?
The VAFC is probably the culprit. Regardless if the company is reputable or not could be a faulty install, take off the VAFC and see if the problem goes away. When your ECU throws a code related to vtec engagement you should start with what is contrlling the VTEC, the VAFC.
I was thinking that that is what I might have to do. Also, I do not consider them reputable anymore since they've been jerking me around since July. Thanks for your help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludesh00 »</TD></TR><TR><TD CLASS="quote">I was thinking that that is what I might have to do. Also, I do not consider them reputable anymore since they've been jerking me around since July. Thanks for your help.</TD></TR></TABLE>
just noticed your from westminister, i'm originally from sykesville. what shop did you take it too?
EIP Tuning. They,ve done everything that i haven't, which is most of the work. Custom exhaust and intake. Real clean and nice but this has gotten out of hand.
Hey Charles,
I saw your post here on my quest to find any helpful information about your problem.What better place to look then in a forum for honda performance!!
Once again I personally apologize for the ridiculous time frame on your car.It is not a normal situation.I completely understand your frustration ,But i want to make it clear that we (EIP) have not forgotten about You. We are constantly searching for the answer.Me Ian JJ Fred all have been on the search and will be extremly happy when this situation is dealt with. I have not called you everyday because i havnt had any good news. Not avoiding.Sorry again for the situation and i hope that we will resolve this VERY soon!
Please give me a call or send me an email if you have any questions
bobby@eiptuning.com
1-410-871-0406
Thanks
Bobby
EIP Tuning http://www.eiptuning.com
bobby@eiptuning.com
1-410-871-0406
Thanks
Bobby
hondagall10
Aug 21, 2010 07:08 PM
