Rough Idle problem
Old Dec 2, 2003 | 02:10 PM
DocV's Avatar
Default Rough Idle problem
I recently did a nice swap to my 2001 gs-r. I put in a a b18c5 block, ported b18c1 head w/ itr valves, valvetrain, ctr cams, skunk2 mani and 8.8 flywheel. After i put that in I idle really bad so I scanned the car and both my o2 were bad so i replaced them and the car idles better, but is still rough going from 900-almost 0 and stallying out. its a intermintent idle problem. I think the problem is that i'm still running a stock OBD2b ecu. any others out there have this problem?
_______
Old Dec 2, 2003 | 02:44 PM
lsvtec hatch05's Avatar
my b16 does this. it is a really rough idle all the time. it started to happen after i put too big of cams in and start floating valves, i pulled out the cams within a week and it has still been doing it ever since. oh well the motor will be out in a week or so and ls vtec will be going in
Old Dec 2, 2003 | 03:08 PM
DocV's Avatar
Default Re: (lsvtec hatch05)
waht cams did you have? b/c I only have CTRs i wouldn't thinkg it would give me a rough idle. thanks for the help
Old Dec 2, 2003 | 05:15 PM
i had top fuel stage 3 cams. big *** lobe cams, you should have absolutely no problem with ctr's
Old Dec 3, 2003 | 05:27 AM
DocV's Avatar
do you think the stock ECU is making the IACV act crazy b/ce its not stock ne more and the compression went up?
Old Dec 3, 2003 | 08:07 AM
i have not a clue about any of that man, sorry
Old Dec 3, 2003 | 11:31 AM
patdemps's Avatar
Have you tuned the car yet? If not then I would.....
Also, do you have aftermarket Pulley setup? I had a unorthodox pulley and it made my idle rough aswell (stalled a few times). It was a bitch, i would never get one again......I was on ITR cams at the time.
Old Dec 3, 2003 | 12:51 PM
DocV's Avatar
Default Re: (patdemps)
i don't have nething to tune. I'm putting a FPR in next week that's about it. but other then that i have nothing.
snzh22
Jul 18, 2007 08:08 PM
Teamdiesel
Jan 16, 2006 07:35 PM
bboy21385
18
Dec 4, 2004 05:39 AM
Crisgo
Apr 7, 2004 08:06 AM
DocV
Dec 2, 2003 05:41 AM
