Can I use old pistons in a new engine ???
Old Dec 2, 2003 | 08:43 AM
yellowturbo's Avatar
Default Can I use old pistons in a new engine ???
I have a set of SRP piston in my engine right now but I have to rebuit the engine... the pistons maybe have like max 15 000 miles... The engine is a D16Z6.
I have a brand new block who doesnt have been oversized ... so could I use my piston with OEM Honda rings in the new engine or I should use brand new piston ???
Any opinion could be great !
Thank...
Old Dec 2, 2003 | 08:53 AM
Seraph0's Avatar
Default Re: Can I use old pistons in a new engine ??? (yellowturbo)
Yeah... you can. Just check the piston/wall clearances.
Old Dec 2, 2003 | 09:04 AM
thank
Old Dec 2, 2003 | 09:57 AM
IN VTEC's Avatar
If you plan on using OEM Honda rings, you should at least check the ring-to-ring groove clearances and check to see if the clearances and ring thicknesses are up to JE's specs. Sometimes forged pistons will use different thicknesses of rings.
Old Dec 2, 2003 | 10:06 AM
T-sohctec's Avatar
Default Re: Can I use old pistons in a new engine ??? (IN VTEC)
You can reuse old pistons, however you may want to take them to a machine shop & have them reconditioned & cleaned.
Old Dec 2, 2003 | 11:01 AM
what do you mean reconditionned ??? the will make them perfectly round ???
Old Dec 2, 2003 | 12:47 PM
Old Dec 4, 2003 | 06:31 AM
T-sohctec's Avatar
Default Re: (yellowturbo)
Reconditioned would mean that they measure them with a micrometer for roundness, and then glass bead them to remove dirt & carbon deposits.
Old Dec 4, 2003 | 06:57 AM
okay thank !
JDM-EJ698
Apr 23, 2009 06:29 PM
honda_ef9
Mar 19, 2007 09:45 PM
crvtkllr
Nov 22, 2006 08:50 AM
nicklk
Jan 27, 2004 12:58 PM
94gsr4d
Jan 29, 2002 08:37 PM
