Anyone Dyno or Gtech Their JDM Lude
Old Dec 2, 2003 | 06:11 AM
h22aLSD
Guest
Posts: n/a
Default Anyone Dyno or Gtech Their JDM Lude
Just like the topic says anyone put a jspec motor in there car and either dyno or gtech it. I ask cause i wanna g-tec it to see wut are some of the #'s i should be looking to get around. I know gtech isnt the best device but a close range of it ..
Old Dec 2, 2003 | 06:14 AM
Crate's Avatar
Default Re: Anyone Dyno or Gtech Their JDM Lude (h22aLSD)
in my sig => intake/header/mut exhuast and a vafc.
Old Dec 2, 2003 | 06:17 AM
v4lu3s's Avatar
RTFM
176 hp 152 ft lbs
test pipe, exhaust and cai
Old Dec 2, 2003 | 06:28 AM
Crate's Avatar
Default Re: (v4lu3s)
thats almost identicle to my baseline run w/out the VAFC. I only gained 4 or so from the vafc.
Old Dec 2, 2003 | 06:50 AM
h22aLSD
Guest
Posts: n/a
Default Re: (Crate)
I got 169.8 and 140.5 tq
with AEM CAI
Greddy evo
and no cat
But my TPS sensor is throwing a CEL you think that could be the reason why im not getting similar numbers!
Old Dec 2, 2003 | 08:04 AM
Daboi630's Avatar
looking for dynos???
see sig mine is the first one
Old Dec 2, 2003 | 04:05 PM
CHK4TIX's Avatar
Default Re: Anyone Dyno or Gtech Their JDM Lude (Daboi630)
i had a Gtech once. that thing was great. one time it said that i had 643hp. even though it obviously was wrong. I sold it shortly after.
Old Dec 2, 2003 | 11:54 PM
h22aLSD
Guest
Posts: n/a
Default Re: Anyone Dyno or Gtech Their JDM Lude (CHK4TIX)
v4lu3s: did you use a dyno or g-tech to get your #'s
Daboi630: thanks that helped a lot. You guys think cause my TPS is out of adjustment it could be missing some HP? and my butterfly valve for the intake runners isnt hooked up yet?
Old Dec 3, 2003 | 02:02 AM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22aLSD &raquo;</TD></TR><TR><TD CLASS="quote">v4lu3s: did you use a dyno or g-tech to get your #'s
Daboi630: thanks that helped a lot. You guys think cause my TPS is out of adjustment it could be missing some HP? and my butterfly valve for the intake runners isnt hooked up yet? </TD></TR></TABLE>
The butterfly valve should only hurt your low end performance, and not affect your peak numbers, as they are open above 4600 anyway.
Get your TPC adjusted for sure. And if you're not using a real dyno, use one.
Old Dec 3, 2003 | 07:16 AM
v4lu3s's Avatar
RTFM
local car shop did a dyno day 3 pulls for $35.
i did one pull all motor and at the time i was spraying as well. first run is just my baseline, 2nd and 3rd were with nitrous, supposedly a 60 shot but it was way too rich....the engine in question had near 100k hard miles on it by the time i got it.
Old Dec 3, 2003 | 05:26 PM
Daboi630's Avatar
it looks like your lines are incomplete????
can you post it in the thread in my link too?
Old Dec 4, 2003 | 07:26 AM
v4lu3s's Avatar
RTFM
the tach lead on teh dyno that day was ******* up i think.it happened to 2-3 other people that day too.
Euro98ITR
Mar 26, 2005 12:45 PM
luap
Oct 27, 2004 09:55 AM
spankaveli
Apr 21, 2002 06:55 PM
Xerzex
Dec 16, 2001 11:56 PM
