what motor oil to use for turbo engine?
Old Sep 17, 2001 | 01:51 AM
ETD4drTeg's Avatar
Default what motor oil to use for turbo engine?
just a question. i was reading the installation manual posted on importparts.com for Drag 3 turbo kits. and it says:
"Use high-grade oil and/or one formulated for use with turbo motors (DRAG utilizes 20-50W Mobile One)."
why 20w50? isn't that too thick? what are the advantages? disadvantages?
Old Sep 17, 2001 | 05:17 AM
RGAZ's Avatar
New User
Default Re: what motor oil to use for turbo engine? (ETD4drTeg)
I don't know what Greddy is thinking but I recommend synthetic ONLY for turbo applications. It maintains its viscosity better, foams less and prevents coking better than dino-oil. My personal preference is Mobil1 5W-30 running in my 2nd gen CRX with t25 at 8 psi. I have had nothing but good results with the Mobil1 and can't say anything bad.
Randy
Old Sep 17, 2001 | 07:19 AM
VTC_CiViC's Avatar
Default Re: what motor oil to use for turbo engine? (RGAZ)
I likewise have used nothing but Mobil 1 in both my cars. 15-50 for the GS-R, 10-30 for the Civic. What do you guys reccomend in terms of weight for the turbo Civic? Mind you I live in S. Fla so for 11 months of the year it's about 80 degrees and humid as hell.
Old Sep 17, 2001 | 11:22 AM
BoostinDC2's Avatar
Default Re: what motor oil to use for turbo engine? (VTC_CiViC)
wht i hear about 20w50 in a honda is that its to thick and it may not lub the bearings all the way. but i just run castrol GTX 10w40
Old Sep 17, 2001 | 03:48 PM
HokieITR's Avatar
New User
Default Re: what motor oil to use for turbo engine? (BoostinDC2)
Anything but true. I ran 20w50 in my Turbo LS. You want the heavy weight to prevent, or at least limit blow by. You use thin oil with a turbo and expect to be burning oil. I highly suggest AMSOil.
Old Sep 17, 2001 | 09:14 PM
turbod97ex's Avatar
New User
Default Re: what motor oil to use for turbo engine? (HokieITR)
I use Amsoil and bought it by the gallon direct from Amsoil instead of going through the "dealers". I paid $160, shipping and tax included, for 4 gallons of the 20-50 Severe Service Racing oil and an oil analysis kit. The oil analysis kit was $20 and comes with a plastic container that you send a sample of your used oil off to a lab to have it analyzed and the results emailed back to you. The oil came out to about $8.40 a quart. http://www.turbocivic.net/images/amzoil.jpg
Old Sep 17, 2001 | 10:09 PM
liam821's Avatar
I run castrol synthetic 5w30 in my turbo civic. Been running great. 5w30 is what is recommended by honda for my engine (d16z6).
liam
Old Sep 17, 2001 | 11:12 PM
Ri5e's Avatar
Default Re: what motor oil to use for turbo engine? (liam821)
use mobile 1 5-30
the20-50 is WAY too thick. You lose performance but in hot weather, it protects better.
in cold weather, 20-50 takes too long to flow to the turbo...not a good thing! it's like syrup.
Old Sep 18, 2001 | 10:06 AM
turbod97ex's Avatar
New User
Default Re: what motor oil to use for turbo engine? (BG Boost)
use mobile 1 5-30
The whole purpose and design of a mulit-viscosity lubricant is that it changes it's viscosity or "weight" depending upon the ambient temperature and the operatinig temperature. Lets take the 20-50 multi-vis as an example. When the weater is the coldest, the viscosity is a 20 weight or the thinnest, not a 50 weight, and as the weather warms up, it will go as far as a 50 weight. In other words, the oil will adapt its viscosity to the ambient air temp and when the engine is warmed up, the viscosity adapts accordingly too.
By the way Liam, I hope you aren't doing everything Honda says to do with your car, their reccomended oil change interval, the type of gas, 87 octane, hehe not good if you are turbo'd, etc. I also like that website, damn you, that's where the .com went! j/k
Old Sep 18, 2001 | 02:42 PM
HokieITR's Avatar
New User
Default Re: what motor oil to use for turbo engine? (turbod97ex)
use mobile 1 5-30
Ya, when you put that turbo on you just threw everything about what Honda says right out the Window, including what oil to run. Do remember you're going to be heating up that oil much more so than a stock car. 20w50 is not anywhere close to syrup, and in fact it's what everyone recommends for turbo engines, including AMSOil and Mobil1, look right on the back of the bottle. But it's your car and your money.
corbina
11
Feb 17, 2014 08:49 AM
JFK78
Sep 28, 2012 01:47 AM
kxrider25
Feb 24, 2011 09:59 AM
Quad-Damage
Apr 7, 2008 02:16 PM
JspekSI24
Sep 13, 2005 05:42 PM
