Looking for cam recommendations.....
Old Dec 1, 2003 | 11:08 PM
Dammit_Dan_954's Avatar
Default Looking for cam recommendations.....
So far this is what I'm getting:
Eagle rods
CP 12:5.1 standard bore (as long as my block is fine that I have)
Clevite bearings
Ferrea springs and crower retainers
stainless high comp valves ( might bump comp by .2 to .3 I think)
Seeing this what cams do you rommend I use and will work with the Ferrea valvetrain?
Modified by FastAssEG at 1:30 PM 12/3/2003
Old Dec 3, 2003 | 09:30 AM
Default Re: Looking for cam recommendations..... (FastAssEG)
Old Dec 3, 2003 | 09:53 AM
Rocket's Avatar
What is your engine size, r/s ratio, intake manifold and header?
JUN3's/Skunk Stage 2 will make good power from 6.5k to 8.5k and most good set ups.
Larger cams like Skunk Stage 3 can make more up top and extend the your rpm range by 500-700 rpms.
Old Dec 3, 2003 | 01:11 PM
vtecb20coupe's Avatar
B A N N E D
Default Re: Looking for cam recommendations..... (Rocket)
if you go with the larger lobe cam, ie jun 3's/skunk 3's, etc, go with a good manifold and header. skunk2 manifold or you can try the new aebs one. as for the header, the an-r and bisimoto ones look promising.
Old Dec 3, 2003 | 05:46 PM
BluePrintmfg.com's Avatar
Banned
I like running JUN 3 or skunk2 stage 2, both cams are very good and will make some nice power on your set-up!
Old Dec 3, 2003 | 11:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">What is your engine size, r/s ratio, intake manifold and header?</TD></TR></TABLE>
B18c1 with skunk2 intake mani and prob dc jdm 4-1.
Old Dec 3, 2003 | 11:54 PM
eyeamvic's Avatar
Bigger cams work well with the 12.5:1. So skunk2 stage 2 or the Jun 3's would be a wise choice. Personally I like the skunk2's.
Old Dec 4, 2003 | 04:37 AM
Soda Popinski's Avatar
Default Re: (eyeamvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eyeamvic &raquo;</TD></TR><TR><TD CLASS="quote">Bigger cams work well with the 12.5:1. So skunk2 stage 2 or the Jun 3's would be a wise choice. Personally I like the skunk2's. </TD></TR></TABLE>
Agreed. JunIIIs or skunk2s would def. Compliment your compression well.
Old Dec 4, 2003 | 07:26 AM
infamousR13's Avatar
Definetly check out ef-1.
Old Dec 4, 2003 | 11:15 AM
Rocket's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FastAssEG &raquo;</TD></TR><TR><TD CLASS="quote">
B18c1 with skunk2 intake mani and prob dc jdm 4-1.</TD></TR></TABLE>
That should work pretty well.
Old Dec 4, 2003 | 01:43 PM
RS Machines's Avatar
We offer billet RS cams that have been dyoned and out performed the big named cams......Dyno sheets to be posted soon
fmrprojects
Feb 1, 2006 11:40 AM
rev2ninetyper
Mar 20, 2005 05:58 PM
SIReg9
Jun 2, 2003 11:56 AM
