Type s swap pro's and con's
Old Dec 1, 2003 | 07:00 PM
cherns's Avatar
Default Type s swap pro's and con's
I am about to swap my f22a out and put in a h22a of some sort. I know i want to go with jdm for the extra power. Now, would it be worth the extra money to get the type S h22a. I found one for 3400 w/ trany and all things needed to swap. Or do I got the the normal jdm h22a with 2000 trany, ecu, lsd for 2650 shipped. Is it worth it for the type s? would the type s be just as good to start modding as the jdm h22a? Also I shouldn't has any trouble putting the type S in my 4 gen would I thanks.
Old Dec 1, 2003 | 07:48 PM
bad-monkey's Avatar
Default Re: Type s swap pro's and con's (cherns)
just get the regular H22.
don't pay 750 bucks for type-S pistons.
Old Dec 1, 2003 | 07:54 PM
Cottonwoodz's Avatar
Default Re: Type s swap pro's and con's (bad-monkey)
750$ for type-s pistons???
Old Dec 1, 2003 | 08:16 PM
bad-monkey's Avatar
Default Re: Type s swap pro's and con's (Cottonwoodz)
well if you're getting the type s swap for 3400, and the reg h22 for 2650 and the fundamental difference being the high cr pistons...
Old Dec 1, 2003 | 08:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">well if you're getting the type s swap for 3400, and the reg h22 for 2650 and the fundamental difference being the high cr pistons...
What aboot the cams, and the mild ported head??
Old Dec 1, 2003 | 08:27 PM
bad-monkey's Avatar
steal the cams!
take a dremel to the head and DIY!
voila.
(yeah i forgot about the cams)
(didn't even realize the PnP head)
Old Dec 1, 2003 | 09:33 PM
ph8ed4life's Avatar
Hey now, we don't condone stealing, do we?? j/k
Old Dec 1, 2003 | 11:12 PM
dankbudz11357's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">just get the regular H22.
don't pay 750 bucks for type-S pistons.</TD></TR></TABLE>
so then i think it would be worth it for the cams, port and polish, and pistons for that extra $750
Old Dec 2, 2003 | 05:41 AM
iakona's Avatar
there's other things:
different internals
different valve angle
hand assembled
just giving all the facts since i have a TypeS/SiR S-spec
Old Dec 2, 2003 | 06:58 AM
skunk2lude01's Avatar
Default Re: (iakona)
how do you have a type-s s-spec?(just messin with ya) , and cherns you will have to find s-spec, type-s will not work in your car.
Old Dec 2, 2003 | 07:04 AM
bad-monkey's Avatar
Default Re: Type s swap pro's and con's (dankbudz11357)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dankbudz11357 &raquo;</TD></TR><TR><TD CLASS="quote">
so then i think it would be worth it for the cams, port and polish, and pistons for that extra $750</TD></TR></TABLE>
i'd agree. i correct my prior ignorance.
but bah what do i know other than being the king of understeer?
my question is, the type S motor/tranny has ATTS, therefore it does not have a mechanical LSD, correct? in that case, i'd say that the H22 w/ LSD for 2650 is what i'd go with because, as cool as ATTS is, it's still not an LSD.
Old Dec 2, 2003 | 08:15 AM
iakona's Avatar
my question is, the type S motor/tranny has ATTS, therefore it does not have a mechanical LSD, correct? in that case, i'd say that the H22 w/ LSD for 2650 is what i'd go with because, as cool as ATTS is, it's still not an LSD.</TD></TR></TABLE>
true, he will have to find an SiR S-spec motor (which everyone sells as a TypeS motor). and i highly recommend it. i love mine.
Old Dec 2, 2003 | 09:21 AM
Nick M's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cherns &raquo;</TD></TR><TR><TD CLASS="quote">I am about to swap my f22a out and put in a h22a of some sort. I know i want to go with jdm for the extra power. Now, would it be worth the extra money to get the type S h22a. I found one for 3400 w/ trany and all things needed to swap. Or do I got the the normal jdm h22a with 2000 trany, ecu, lsd for 2650 shipped. Is it worth it for the type s? would the type s be just as good to start modding as the jdm h22a? Also I shouldn't has any trouble putting the type S in my 4 gen would I thanks.</TD></TR></TABLE>
Its a waste of money anyway you look at it. Buy a regular JDM h22a with an LSD and use the difference in $ to buy an SMSP or Hytech Header and you'll have more power than an SiR S-spec motor
Old Dec 2, 2003 | 09:28 AM
BolivianFuego's Avatar
Default Re: Type s swap pro's and con's (Nick M)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick M &raquo;</TD></TR><TR><TD CLASS="quote">
Its a waste of money anyway you look at it. Buy a regular JDM h22a with an LSD and use the difference in $ to buy an SMSP or Hytech Header and you'll have more power than an SiR S-spec motor</TD></TR></TABLE>
Agreed.
Old Dec 3, 2003 | 07:55 PM
cherns's Avatar
But if I went the path of the "normal" h22a. I would get a torque curves that is not as good as the type S, Correct? The headers would possibly make up the HP but not the torque curve. I am kinda set on the idea of a Type S engine, as of moment. So the type S will come with ATTS? If so will it work with a 4th gen? Finally I figure the S-spes id the type s correct? thanks
Old Dec 3, 2003 | 09:55 PM
Gerhard_001's Avatar
You can get it to fit, but goodluck on wiring it up to work as it is a pain. Go with the S-spec motor as you are starting with a more powerful motor, you can usaully get the company who is selling the engine to swap the tranny's for a little extra cash.
soclean1k_JDM
May 20, 2009 12:57 AM
8_6 luder
Jul 27, 2007 02:06 PM
vtec420kingH22
Oct 14, 2005 06:45 PM
accord-25
Apr 18, 2005 07:43 PM
Jin Yamato
Oct 26, 2002 12:45 PM
