92 LS into 93LS swap...IT WONT START HELP!!
Old Dec 1, 2003 | 06:17 PM
93FastLs's Avatar
Default 92 LS into 93LS swap...IT WONT START HELP!!
i just swapped in a 92 LS motor..into my 93 LS the. hooked up everything... but when i start it...all i hear is the motor trying to crank..took out one of the plug wires and stuck in a new plug and tried to start it over and there was no spark at all on the electrode..i have no friggen idea what happend ? i went over the harness and everything is plugged in..but im just so stumped on this car... if anyone could please get back to me thanks..
Old Dec 1, 2003 | 07:03 PM
ISawUL00k's Avatar
Default Re: 92 LS into 93LS swap...IT WONT START HELP!! (93FastLs)
Did you do anything with the distributer before the swap ?
check ur grounds to the tranny the thermastat and the head...
Old Dec 2, 2003 | 04:20 AM
VTECVillain's Avatar
Default Re: 92 LS into 93LS swap...IT WONT START HELP!! (ISawUL00k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ISawUL00k &raquo;</TD></TR><TR><TD CLASS="quote">check ur grounds to the tranny the thermastat and the head...</TD></TR></TABLE>
Yes this is something that people sometimes forget or overlook and it can cause the car not to start.
Old Dec 2, 2003 | 12:26 PM
93FastLs's Avatar
thanks alot guys for the quick info...ima check all the grounds tonight...
Old Dec 2, 2003 | 04:38 PM
ISawUL00k's Avatar
make sure ur plugs are right like a backwards Z S on ur distributer
top right is 1, top left is 2 ,bottom right is 3, bottom left is 4
if that doesnt work give a couple bangs with a big wrench.....Hard....lol
Old Dec 2, 2003 | 05:11 PM
93FastLs's Avatar
i havent touched the distributor... on it
Old Dec 8, 2003 | 08:19 PM
ISawUL00k's Avatar
does it atleast turn over ?
Old Dec 9, 2003 | 05:09 PM
93FastLs's Avatar
nope.. all i hear is it trying too.. i took the plug out and connected the plug wire to it..and there's is no spark what so ever
Old Dec 17, 2003 | 08:54 AM
ISawUL00k's Avatar
Default Re: (93FastLs)
so the starer works then right.?
check all the wire harness grounds. Take ur ECU out and find ur HOT wire for ur Year and model that powers the ECU one the harness clips. When u find it turn the car on and see if u get power. I think it will still send power without the ECU there. and if that doesnt work there is ur problem. Maybe Pull off the Map senser and see if it will throw a code with the accesseries on. Hope that works. Or/And Take ure cap off and put a tester to the + side of the coil see if u get power.. Good Luck
Old Dec 17, 2003 | 03:18 PM
93FastLs's Avatar
thanks alot man.. im gonna try it..
Old Dec 19, 2003 | 04:29 PM
ISawUL00k's Avatar
Anything ?
Timmyflys
Mar 10, 2010 11:33 AM
sLoWrAcEr
Jan 16, 2010 08:38 PM
drift2004
Nov 10, 2007 10:03 PM
