another opinion on 92-95 cat back exhaust... turbo though.
i have a 95 coupe, i got a GSR engine in there right now and i want to turbo, whats a good turbo cat back... i guess 2 1/2" - 3"?
and high flow cat? will this bolt right up to the turbo or will i need to get some welding done?
looking to spend under like 1000 for both catback and high flow cat
thanks
oh and sound clips rule
thanksoh and sound clips rule
if the high flow cat has the connectors for the factory header then it will hook right up BUT if you get a downpipe that doesnt connect to the cat then you will have the cut and weld them together
edit: yea if you are not making over 275 horses then just go with 2½ inch piping
apex n1 is a good cat back exhaust that i would recommend
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95DXPhiladeph »</TD></TR><TR><TD CLASS="quote">i have a 95 coupe, i got a GSR engine in there right now and i want to turbo, whats a good turbo cat back... i guess 2 1/2" - 3"?
3" Thermal.............You cant go wrong with that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO »</TD></TR><TR><TD CLASS="quote">
3" Thermal.............You cant go wrong with that.</TD></TR></TABLE>
Yup. Thermal is the brand btw. 3 inch for FI y0!
TehMan
Jan 20, 2006 09:10 AM
igo4bmx
Apr 5, 2005 10:03 AM
