peak and hold injectors
Old Sep 16, 2001 | 09:33 PM
Mikex25's Avatar
New User
Default peak and hold injectors
I wanted to get the 92-96 prelude injectors and I heard the are peak and hold injector what would I need to make it work on saturated injectors. I am using this in my GSR with rev hard 2 w/ bosch pump.
[Modified by Mikex25, 7:15 AM 9/17/2001]
Old Sep 17, 2001 | 07:22 AM
dustin's Avatar
Default Re: peak and hold injectors (Mikex25)
You will need the injector resistor box out of an older honda. It is a silver heatsink-looking box at the top right corner of the engine bay (to the right of the brake MC) when looking from the front.
Dustin
Old Sep 17, 2001 | 10:57 PM
Mikex25's Avatar
New User
Default Re: peak and hold injectors (dustin)
When I get the older model injector resistor pack would I need to get it from an older year integra. What year injector resistor pack would I need and from what car? alright thanks alot.
Old Sep 18, 2001 | 06:09 AM
VTC_CiViC's Avatar
While we're on these lines, is there a way to determine wether you have peak/hold or saturated injectors? I didn't know about the 2 when I bought the H22A injectors for my Civic and although I think I recall reading them as saturated injectors, i'm not 100% sure so I'm a little worried right now. So is there some kind of physical feature on them that sets them apart or am I screwed untill I install them and see if they work?
Old Sep 18, 2001 | 09:32 AM
IgniteTeg's Avatar
What are the pro and cons with the peak and hold and saturated injectors and non saturated?? Whats better? What are they?? Thanks.
Old Sep 18, 2001 | 12:42 PM
sgT's Avatar
sgT
Default Re: peak and hold injectors (VTC_CiViC)
Measure the resistance of the injectors.
Saturated will see about 12-16Ohms(pretty sure on that)
whereas peak hold will be about 6
Old Sep 18, 2001 | 02:28 PM
Turbolude's Avatar
Just to let you know i have the resistor box and injectors for a 93 Vtec prelude which are peak and hold. Email me if interested
Old Sep 18, 2001 | 02:41 PM
TurboT's Avatar
Default Re: peak and hold injectors (Turbolude)
i can build you some resistor boxes for pretty cheap...
maybe this will be my project
Old Sep 18, 2001 | 02:49 PM
Mikex25's Avatar
New User
Default Re: peak and hold injectors (TurboT)
What would I need to do exactly to make prelude injectors work on my 2000 GSR? Just get the injectors, resistor box, OBD II plugs. Thats it though right? or am i missing anything
Old Sep 18, 2001 | 03:01 PM
sgT's Avatar
sgT
pre96 injector plugs.
Old Sep 18, 2001 | 03:18 PM
Turbolude's Avatar
Im pretty sure that i can give you my injector plugs too.
BoostinTEG
Jan 22, 2011 06:34 AM
ironiceghatch
Feb 11, 2008 01:26 PM
nolicense526
Jul 31, 2007 06:17 AM
swt_666
May 16, 2007 09:33 PM
Schister66
Apr 26, 2006 08:36 AM
