what's everyone's opinion on precission injectors!!!!!!!!!!!!!!!!!!!!!!!!!
Old Dec 1, 2003 | 03:21 PM
allstokhonda's Avatar
Default what's everyone's opinion on precission injectors!!!!!!!!!!!!!!!!!!!!!!!!!
I'm am in the ordering proccess right now of gettin all the parts for my engine build. I'm build a 2.0L darton sleeved gsr with my b16 head. it gonna have 9.0:1 cr and I looking to run around 15-18 psi around town and 20-23 psi at the track on race gas. are precision injectors anygood. I don't know much about them. just that I can get 880cc for around 75$ (each) and 1000cc or like 85-90. anybody with any knowledge of this that would like to post. WOuld be greatly appriciated.
Old Dec 1, 2003 | 03:23 PM
b18bturbo's Avatar
Default Re: what's everyone's opinion on precission injectors!!!!!!!!!!!!!!!!!!!!!!!!! (allstokhonda)
i had one set fail but ever since that not single failure .. they use Rochestor Core in there mid range injectors from 680cc-1000cc and the 1600cc is a bosch unit
the 880cc should be good for your setup
Old Dec 1, 2003 | 03:26 PM
11psiTurboSI's Avatar
Default Re: what's everyone's opinion on precission injectors!!!!!!!!!!!!!!!!!!!!!!!!! (b18bturbo)
Never had a problem with Precision injectors!
Old Dec 1, 2003 | 03:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">i had one set fail but ever since that not single failure .. they use Rochestor Core in there mid range injectors from 680cc-1000cc and the 1600cc is a bosch unit
the 880cc should be good for your setup</TD></TR></TABLE>
thanks for the reply. I was told that I need a resistor box. if so do you know of anywhere I can locate or purchase one. also I talk to kyle at wiredspeed and he recommended them but I just figured I could look around and talk to some more people.
Old Dec 1, 2003 | 03:31 PM
JDogg's Avatar
we use the 880's and have no problems with them at all.
you will need a resistor box.
i was under the impressoin that they were delphi injectors?
Old Dec 1, 2003 | 03:37 PM
b18bturbo's Avatar
Default Re: what's everyone's opinion on precission injectors!!!!!!!!!!!!!!!!!!!!!!!!! (JDogg)
GM delphi uses rochestor product if you take a look at your injector you will see RP cast on the side of the injector
Old Dec 1, 2003 | 03:39 PM
[QUOTE=JDogg]we use the 880's and have no problems with them at all.
QUOTE]
what kinda power are you making and/or et's/ in what car
Old Dec 1, 2003 | 03:46 PM
anyone else have anything to say. any comments are welcome
Old Dec 1, 2003 | 03:47 PM
b18bturbo's Avatar
Default Re: (allstokhonda)
get them they are good priced works great compared to the outragerous price of RC also you can check out another brand called Simen Deka i think camp1320 sells them on here
Old Dec 1, 2003 | 03:52 PM
Default Re: (b18bturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">get them they are good priced works great compared to the outragerous price of RC also you can check out another brand called Simen Deka i think camp1320 sells them on here </TD></TR></TABLE> yeaht that's what I'll probably do. yeah the RC are freakin 180 each. that's a little high compared to precisions only being 75-90$ each.
Old Dec 1, 2003 | 05:13 PM
JDogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allstokhonda &raquo;</TD></TR><TR><TD CLASS="quote">[QUOTE=JDogg]we use the 880's and have no problems with them at all.
QUOTE]
what kinda power are you making and/or et's/ in what car</TD></TR></TABLE>
last time we were on the dyno we made 510hp and 375 tq. we are close to maxing the injectors out, the base pressure is around 55 psi
Old Dec 1, 2003 | 05:17 PM
ndogg's Avatar
thanks for the reply. I was told that I need a resistor box. if so do you know of anywhere I can locate or purchase one. also I talk to kyle at wiredspeed and he recommended them but I just figured I could look around and talk to some more people.</TD></TR></TABLE>
just buy some resistors from radio shack for like $2.
Old Dec 2, 2003 | 05:39 PM
JDogg's Avatar
Default Re: what's everyone's opinion on precission injectors!!!!!!!!!!!!!!!!!!!!!!!!! (ndogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndogg &raquo;</TD></TR><TR><TD CLASS="quote">
just buy some resistors from radio shack for like $2. </TD></TR></TABLE>
or go get one out of any 90-97 accord or 92-96 prelude or 88-91 civic for bout 20 bux
Old Dec 2, 2003 | 05:46 PM
boostaholic's Avatar
what kind of ECU are you using to run the injectors? You don't necessarily need a resistor box unless you're running an ECU that's setup for high impendence injectors.
Old Dec 2, 2003 | 07:19 PM
ndogg's Avatar
Default Re: what's everyone's opinion on precission injectors!!!!!!!!!!!!!!!!!!!!!!!!! (boostaholic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostaholic &raquo;</TD></TR><TR><TD CLASS="quote">what kind of ECU are you using to run the injectors? You don't necessarily need a resistor box unless you're running an ECU that's setup for high impendence injectors. </TD></TR></TABLE>
what ecu could he run with low impedence injectors without a resistor box?
Old Dec 2, 2003 | 07:54 PM
JDogg's Avatar
some standalones can. im not sure which though.
Old Dec 2, 2003 | 09:24 PM
what ecu could he run with low impedence injectors without a resistor box?</TD></TR></TABLE>
Autronic, Motec, Speedpro/FAST, DFI, and haltech all have built in drivers for low impendence injectors.
Old Dec 2, 2003 | 09:43 PM
TurboDANDEE's Avatar
i run Precision 85 lbs. no problems so far...
Old Dec 3, 2003 | 12:00 AM
Seraph0's Avatar
Default Re: what's everyone's opinion on precission injectors!!!!!!!!!!!!!!!!!!!!!!!!! (TurboDANDEE)
I just picked up a set of Precision 880cc injectors from Arturbo. I'm putting my trust in them.
Old Dec 3, 2003 | 01:12 AM
slowsi00's Avatar
i really dont think ever hearing any problems at all with any precision products.
Old Aug 5, 2006 | 11:36 AM
HatchEh2's Avatar
Default Re: (slowsi00)
BACK FROM THE DEAD, im about to pick up a set of precission 450cc injectors from a friend for pretty cheap. putting them in my SOHC... its a d16z6 in an EG hatch... do i need a resistor box aswell? and what is it used for? keeps them from being over powered or something?
also did anyone ever use these on a sohc? did you have any problems? where they enough for your setup? im shooting for 250whp stock motor..
Old Aug 5, 2006 | 01:42 PM
qfast817's Avatar
Default Re: (HatchEh2)
ive had my injectors for 6 months with no problems, you might want to run 1000cc so you can turn up the boost later on
Old Aug 5, 2006 | 01:52 PM
Dunc's Avatar
BCICAN
Default Re: (qfast817)
Using 1000's and they are working just fine for me since September 2005
Old Aug 5, 2006 | 03:07 PM
Topdawgg's Avatar
ihavent heard anything bad about precision... i opted to go with the RC's though
Old Aug 5, 2006 | 03:36 PM
sc4dr's Avatar
Default Re: (Topdawgg)
My 880's are working well
B18 rider
Aug 8, 2008 10:51 AM
rsxtypes04
Aug 29, 2007 06:19 AM
chieu
Jul 3, 2007 09:18 AM
ella94
Jul 6, 2006 06:08 AM
Vtec92Civic
Mar 11, 2004 08:17 AM
