affects of running of worn piston rings???
Old Dec 1, 2003 | 03:07 PM
jeremy.'s Avatar
Default affects of running of worn piston rings???
i might have worned out pistons rings....what's the negatives of me running on them until i get them changed? any block damage? what about a leaking headgasket? thanks in advance
Old Dec 1, 2003 | 03:51 PM
Kendall's Avatar
You'll get blowby resulting in an improper mixture of air and fuel which leads to incomplete combustion which over a period of time can damage components such as the head gasket, valves, spark plugs, etc. You'll also be down on power a bit.
Old Dec 1, 2003 | 05:07 PM
91tegrals's Avatar
yeah he right just dont romp on the car till you can get it fixed...
Old Dec 1, 2003 | 05:13 PM
LudeyKrus's Avatar
It'll cause a good loss in power, and may eat plugs quicker, but I've heard one of the bigger things is that it will cause the oil to get contaminated from the gasses blowing into the crankcase, decreasing the longevity of the motor.
Old Dec 1, 2003 | 05:17 PM
Kendall's Avatar
Default Re: (LudeyKrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">It'll cause a good loss in power, and may eat plugs quicker, but I've heard one of the bigger things is that it will cause the oil to get contaminated from the gasses blowing into the crankcase, decreasing the longevity of the motor.</TD></TR></TABLE>
It does that too. I didn't think about it earlier because I change my oil so damn much anyways.
rocko5845
37
Nov 29, 2010 08:21 AM
99gsvtec
15
Apr 19, 2010 01:02 PM
CRX_Control
37
Feb 24, 2005 09:55 PM
BlazeTeck2000
Feb 11, 2005 01:05 PM
TURBOED-TEG
Aug 25, 2002 03:29 PM
