changing piston rings w/out pulling motor?
you can do it form the top but you also have to open the pan and remove the rod bolts and mains. It easier if you just pull your entire block out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo »</TD></TR><TR><TD CLASS="quote">you can do it form the top but you also have to open the pan and remove the rod bolts and mains. It easier if you just pull your entire block out.</TD></TR></TABLE>
I disagree. It's alot easier in the car. Don't have to touch the mains.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_jeremy »</TD></TR><TR><TD CLASS="quote">can you hone the block also w/out pulling the block?</TD></TR></TABLE>
yes
yes
It isn't terribly hard, but it isn't as easy as honing them with the block out either. You would probably want to remove the front bumper cover, and bumper support to get you closer to the block.
