Which car GSR into sol
Old Dec 1, 2003 | 12:41 PM
asmallsol's Avatar
Default Which cat GSR into sol
Edit: The title should have said which CAT
My goal is to keep my catback unmodied, keep the stock header/collector location and just make up the diffrance in the cat. Right now, I have a full GSR car at my disposal. It has the OEM cat, ect.
Reason I want to not modify the cat back is, I am waiting for RSR to produce a catback FOR the del sol. Right now, I could just use the EG's and do a little cutting. However, If I do this, the welds will end up rusting through and then the quality of the exhaust is lost. If I just get a coustom size cat, no welding, my setup can last for years to come.
What do I need to do to make this work. Would just using the stock GSR cat work or do I need something shorter or longer?
Modified by asmallsol at 3:59 PM 12/1/2003
Old Dec 1, 2003 | 02:58 PM
asmallsol's Avatar
Default Re: Which cat GSR into sol (asmallsol)
bump
Old Dec 1, 2003 | 03:34 PM
VTECVillain's Avatar
The GSR cat will not make up the difference in length, the GSR header is physically shorter than other B series, about 4" shorter. You could:
1.) Buy a B16/ITR header and it will be the proper length then use a standard Civic or Integra cat. converter and it should line up with the exhaust side flange.
2.) Use a GSR header or GSR stock manifold and then have an exhaust shop make an extension piece to go between the cat and header.
jdm_94
Nov 5, 2009 08:22 AM
finest_GSR
Mar 5, 2006 06:07 PM
Mugen112
Jul 14, 2005 04:48 AM
phrasathane
Jan 19, 2004 04:07 PM
