I can't get my shift knob off!!!!!!
Old Dec 1, 2003 | 11:48 AM
EJ1 wilcox's Avatar
Default I can't get my shift **** off!!!!!!
I know, I know... this sounds easy!! I have had many different shift ***** on my car yada yada and never had any problems getting the shift **** off....
I now have a DC shifter with a DC shift ****. I am trying to get it off so I can put my stock **** back on for the winter, but I can't get that sucker off for the life of me!
I have tried almost everything! My hands are killing me!!
Has this happened to anyone else? I don't know what the deal is but that thing is on there like none other...
Does anyone have any good tips or tricks that might help me get this thing off???
Any held would be much appreciated!!
Would it be easier to get the **** off if I let the car warm up so the shifter warms up etc? I can't think of anything else!!
Old Dec 1, 2003 | 11:53 AM
eL's Avatar
eL
Default Re: I can't get my shift **** off!!!!!! (koreanwilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koreanwilcox &raquo;</TD></TR><TR><TD CLASS="quote">
Would it be easier to get the **** off if I let the car warm up so the shifter warms up etc? I can't think of anything else!!</TD></TR></TABLE>
Yeah i would just warm it up. It's either that or the torch. We wouldnt want that. Goodluck getting it off though.
Old Dec 1, 2003 | 11:54 AM
rodrez.'s Avatar
Maybe wrap a rag around the shifter, and use large pliers or channel locks to get a grip on it.
Se-rv-Tak's Avatar
As long as it's not welding on or anything, you should be able to just twist it off. But it could be different, I don't have first-hand experience with that shifter and shift ****.
Evs-One's Avatar
Solbros Owns Me
Default Re: I can't get my shift **** off!!!!!! (eL)
use some muscle
Old Dec 1, 2003 | 11:55 AM
EG2 SiR's Avatar
Default Re: I can't get my shift **** off!!!!!! (rodrez)
same thing happened to my dc shifter w/ spoon ****. I had to put the end of the shifter in a vice and a leather belt to remove the ****.
Old Dec 1, 2003 | 11:56 AM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
why are you changing your shift **** for winter?
use your brain.. it's a damn shift **** for god's sake.. problem solving is KEY
Old Dec 1, 2003 | 11:57 AM
cegleitz's Avatar
get one of the fubber grip things that tighten and don't move. I have one stuck on there and used of the rubber things(can't think of their name) and it came right off.
solsteeler's Avatar
Letting it warm up before you try and remove it shouldn't work. When metal heats up it expands, and that would make it tighter. Have you tryed putting a rag around it. Maybe you could use a couple of rags and a pipe wrench. Put the pipe wrench on the shift **** and turn that bit@h. It sounds like you cross threaded it when you put it on.
cegleitz's Avatar
change it cause it's winter and really cold when your shifting?
Old Dec 1, 2003 | 11:58 AM
jarel's Avatar
Default Re: I can't get my shift **** off!!!!!! (Hatchy-Ownzjo0)
when you put that DC **** on in the first place....did you happen to put any puddy or something on the threads to lock it in?? Try and yellow rubber kitchen glove and awhole lot of body strength.
Old Dec 1, 2003 | 11:59 AM
CNY Hatch's Avatar
I think craftsman sell a tool that has a rubber band type thing going through it where the harder you try to tighten or loosen something it grabs harder... I would try that... I think it's one of those multi-use tools, where you can use it to take off tops of jars n' stuff....
Old Dec 1, 2003 | 12:13 PM
EGRhatch's Avatar
Default Re: (CNY Hatch)
elbow grease my frined, elbow grease is key you weakling
try what everyone else said and just wrap it and then use a wrench to get it off GL
Se-rv-Tak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CNY Hatch &raquo;</TD></TR><TR><TD CLASS="quote">I think craftsman sell a tool that has a rubber band type thing going through it where the harder you try to tighten or loosen something it grabs harder... I would try that... I think it's one of those multi-use tools, where you can use it to take off tops of jars n' stuff.... </TD></TR></TABLE>
Old Dec 1, 2003 | 12:18 PM
Street Ghost's Avatar
Default Re: (Soon2B18Boost)
use a lot of muscle and GRUNT! grrrrrr
Old Dec 1, 2003 | 12:28 PM
pdiggitydogg's Avatar
a belt wrench would work
Old Dec 1, 2003 | 12:29 PM
AWDxBOOST's Avatar
Default Re: (93 EJ1)
get one of those openers that has a rubber belt on it
or you can make one yourself
somethin like this
Old Dec 1, 2003 | 12:43 PM
Foozball26's Avatar
get your mom to get it off for you since you can't
goto the gym for a few weeks and twist that sucker off.
Old Dec 1, 2003 | 12:46 PM
The Internet Tough Guy's Avatar
Default Re: I can't get my shift **** off!!!!!! (Foozball26)
chainsaw
Old Dec 1, 2003 | 12:51 PM
Infinity_Racer's Avatar
Default Re: I can't get my shift **** off!!!!!! (jwn7)
eat some spinach and twist that bitch off
popeye the sailor man....toot toot
Old Dec 1, 2003 | 01:10 PM
EJ1 wilcox's Avatar
Default Re: I can't get my shift **** off!!!!!! (Infinity_Racer)
Thanks for all the help guys!!
I still am not sucessful but I tried getting it off with a belt and vice grips... didn't work!!!
This thing is killin me!!
I twisted it about a half turn but it's not goin any further. I swear I'm not that weak and both my hands are blistered from trying to get that stupid thing off!!
I noticed little pieces of metal are coming off when I try to turn it. I think I am goin to have to cut that sucker off...
Old Dec 1, 2003 | 01:11 PM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchy-Ownzjo0 &raquo;</TD></TR><TR><TD CLASS="quote">problem solving is KEY </TD></TR></TABLE>
LOL!
Old Dec 1, 2003 | 01:19 PM
EG2 SiR's Avatar
It's gonna snap off some of your shifter.....
Old Dec 1, 2003 | 01:22 PM
Default Re: I can't get my shift **** off!!!!!! (EG2 SiR)
are u sure youre not turning it the wrong way
rightey tighty, left loosey
Old Dec 1, 2003 | 01:36 PM
Gump's Avatar
Default Re: I can't get my shift **** off!!!!!! (93 EJ1)
You might have cross-threaded the **** to the shifter. It happened to me once, I used vise grips to take it off, didn't work ended up making it really lose that it just spun around but didn't come off. I had to resort to cutting the **** off, and having to buy a new short shifter and ****.
