-HYpothetical question-
Old Dec 1, 2003 | 10:57 AM
0 0 0's Avatar
Default -HYpothetical question-
say i was to build a single cam block(crx si 1.6 non-vtec) but i want to have low compression like the single cam vtec block to go with the vtec head. If i was to build the crx block and buy forged pistons and rods would it matter if i used a non-vtec(crx) or vtec(z6) block? would the compression be the same on both blocks if i used the same pistons and rods? What is the difference between non-vtec and vtec single cam block?
Old Dec 1, 2003 | 11:03 AM
solsteeler's Avatar
Default Re: -HYpothetical question- (vxHATCHATTACK)
If I remember correctly the internals on vtec and non should be interchangable. If I'm wrong someone please correct me.
Old Dec 1, 2003 | 11:07 AM
92BlackSi's Avatar
You would have to remove the oil control jet valve other than that I am not sure. CRX is A6 in case you wondering.
Old Dec 1, 2003 | 11:26 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: (92BlackSi)
same block, same crank, and I believe the same size rods.
Piston dome volume varies though, along with cc's in each head.
Old Dec 1, 2003 | 11:36 AM
Spartanic's Avatar
The D series VTEC blocks may have oil squirters on the bottom of each cylinder bore, that's the difference betweet non vtec D series blocks.
Old Dec 1, 2003 | 12:26 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: -HYpothetical question- (Spartanic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spartanic &raquo;</TD></TR><TR><TD CLASS="quote">The D series VTEC blocks may have oil squirters on the bottom of each cylinder bore, that's the difference betweet non vtec D series blocks.</TD></TR></TABLE>
no they don;t
Old Dec 1, 2003 | 12:29 PM
jeremyEG's Avatar
Default Re: -HYpothetical question- (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">
no they don;t</TD></TR></TABLE>
Old Dec 1, 2003 | 12:46 PM
Dancing is Forbidden's Avatar
Default Re: -HYpothetical question- (Kikomon)
dangit. Check it. You cant use 1.5 liter pistons in a 1.6 because of wristpin location. You can use 1.6 in 1.6 though. AND the VX is a special case that I am not 100% sure of what you can use there. Also. Each is going to give you different CR numbers. Say if you used z6 pistons in a a6 you are going to get lower cr. But if you do the opposite, the numbers are higher. Just buy the right stuff.
Old Dec 2, 2003 | 11:35 AM
0 0 0's Avatar
Default Re: -HYpothetical question- (EF9_SiR)
no im not talking about putting 1.5 pistons or any parts 1.5 into a 1.6 block im basically asking what makes the compression higher when when u have a vtec head on a a6 block rather then the z6 block...? is it the pistons? rods? is the stroke shorter or longer?
Old Dec 2, 2003 | 11:43 AM
mattssi's Avatar
The z6 has tighter clearances inside the cc if i remember correctly, bsically there is more room inside the a6 head, thus making it have less compression #'s. Less room = more compression!
Old Dec 2, 2003 | 05:56 PM
0 0 0's Avatar
Default Re: -HYpothetical question- (mattssi)
okay so now that we have that out of the way what are some good low compression pistons for turbo. rods also.
hard_code
13
Nov 14, 2012 04:05 PM
omnijdm
Feb 8, 2012 09:16 AM
Metal Head
Feb 16, 2009 11:44 AM
JDM_rolex
Mar 16, 2006 09:53 PM
RATED EG
Nov 13, 2005 11:30 PM
