1995 Honda accord ex ABS dummy light
Old Dec 1, 2003 | 10:13 AM
vtec4gcivic's Avatar
Default 1995 Honda accord ex ABS dummy light
The abs dummy light blinks a 42 code any idea what that is? it blinks four times then twice.
Thanks,
Karl
Old Dec 1, 2003 | 02:06 PM
Chiovnidca's Avatar
Default Re: 1995 Honda accord ex ABS dummy light (vtec4gcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec4gcivic &raquo;</TD></TR><TR><TD CLASS="quote">The abs dummy light blinks a 42 code any idea what that is? it blinks four times then twice.
Code 4-2. Problem with the left front wheel speed sensor.
Possible causes:
Open circuit,internal short or short to body ground in the left-front wheel sensor
Open circuit or short to body ground in the positive (+)wire between the left-front wheel sensor and ABS control unit
Open circuit or short to body ground in the negative (-)wire between the left-front wheel sensor and ABS control unit
Positive (+)wire shorted to the negative (-)wire between the left-front wheel sensor and ABS control unit
Loose connector or poor contact of terminals
Improper left-front wheel sensor air gap
Faulty ABS control unit
Missing left-front pulser
Modulator does not decrease pressure properly
Wheel lock by downshift
FasterScooter
Honda CR-V & Element
Jan 21, 2013 06:57 AM
Whatislove
Honda Civic (2001 - 2005)
16
Jun 14, 2009 01:53 PM
ludee00
Nov 21, 2005 04:22 AM
JDM97R
Aug 13, 2004 10:31 AM
99sonicbluegsr
Mar 4, 2004 06:13 AM
