Difference between ITR and B16 tranny's?
Old Dec 1, 2003 | 09:47 AM
Sassafrass's Avatar
Default Difference between ITR and B16 tranny's?
I was having a discussion with a friend of mine about the difference in an ITR tranny and B16. I'm gonna keep things simple (or else I'll loose my train of thought) He says the only difference between the 2 tranny's is that the ITR has a better final drive and LSD. Obviously that is true but he also said the gearing is the exact same for both, is this true?
Old Dec 1, 2003 | 09:49 AM
Spade's Avatar
Default Re: Difference between ITR and B16 tranny's? (Sassafrass)
Er.
http://ff-squad.com/Bgears.htm
BauleyCivic's Avatar
Risky Business
Actually the two trannies are nearly identical with the exception of the LSD. The B16 I believe has a slightly better 4th gear. See for yourself:
http://www.ff-squad.com/Bgears.htm
Old Dec 1, 2003 | 09:55 AM
Spade's Avatar
Default Re: Difference between ITR and B16 tranny's? (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">Actually the two trannies are nearly identical with the exception of the LSD. The B16 I believe has a slightly better 4th gear. See for yourself:
http://www.ff-squad.com/Bgears.htm</TD></TR></TABLE>
Depends on the year.
Old Dec 1, 2003 | 10:03 AM
Ricey McRicerton's Avatar
Default Re: Difference between ITR and B16 tranny's? (Spade)
Also, the FD depends on years.
Old Dec 1, 2003 | 10:05 AM
Risky Business
Default Re: Difference between ITR and B16 tranny's? (Ricey McRicerton)
Yeah, I was assuming he was comparing USDM 99-00 Si trannies and 97-01 USDM ITR trannies.
Old Dec 1, 2003 | 10:06 AM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Also, the FD depends on years. </TD></TR></TABLE>
yes
pre 98 itr had 4.4 98 and newer itr had 4.785
schimmer
Jun 3, 2008 05:01 PM
VTiSoL
Oct 2, 2006 04:05 AM
mikkey1
17
Jun 9, 2006 08:58 AM
sluggo
Mar 1, 2006 07:28 AM
crazy eyez killa
Nov 24, 2003 09:01 AM
