94+ teg radiator in EG
Old Nov 30, 2003 | 09:24 PM
JDMlyfestyle's Avatar
Default 94+ teg radiator in EG
I was wondering can you use the AC mounts in a EG for the Integra Radiator. has any one had any problems with this? does you engine stay any cooler.. leave feed back Thanks Jason
Old Nov 30, 2003 | 09:25 PM
GTlvr82's Avatar
Default Re: 94+ teg radiator in EG (JDMlifestyle)
SEARCH LIKE WOA...j/p. I do believe that you can. If you buy the Fluidyne radiator for the integ. I believe it swaps in.....but I will bow out to the more knowledge-able.
Old Nov 30, 2003 | 09:28 PM
G-money's Avatar
no you need to drill supports off (both) and center them really wasy then just tack weld them back on and make some kinda upper brackets i used teg uppers flipped upside down and mounted them under the rad support (had to drill holes) and bolt on with 10mm bolts...
Old Nov 30, 2003 | 09:29 PM
GTlvr82's Avatar
Default Re: 94+ teg radiator in EG (All MTR TODA HATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by All MTR TODA HATCH &raquo;</TD></TR><TR><TD CLASS="quote">no you need to drill supports off (both) and center them really wasy then just tack weld them back on and make some kinda upper brackets i used teg uppers flipped upside down and mounted them under the rad support (had to drill holes) and bolt on with 10mm bolts...</TD></TR></TABLE>
Thank you...I knew it fit though.
Old Nov 30, 2003 | 09:31 PM
Thanks guys. do u know if the engine stays cooler or any complications with it?
G-money's Avatar
Default Re: 94+ teg radiator in EG (GTlvr82)
i have a fluidyne teg i mine now kinda a tight fit tho...cause its so wide but it stays cold all the time never gets above operating temp even at idle....fan hardly ever comes on...
Old Dec 1, 2003 | 02:00 AM
do u have like a mugen thermostat or ne thing like that.. was it worth it in your opinion?
Old Dec 1, 2003 | 05:15 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
i had a full length integra fluidyne in my civic. temps were 170 degrees while cruising in the summer. it would creep to 185 degrees in traffic on a hot day. i have since swapped to a stock integra radiator. temps are 175-180 while cruising, 190-200 in traffic/hot day. if you have the $, i suggest the fluidyne. i was taking every possible weight reduction, the reason for my swap to a stock radiator. there you go, some real #'s.....
edit: this is with a mugen thermostat/ b series swap. i am going to try the spoon, as i have heard it runs cooler than the mugen, but i have no hard facts as of yet. i will test them and let you guys know my findings.
peshte
Sep 20, 2005 08:28 AM
JDMlyfestyle
Jan 26, 2005 09:33 AM
EG6_SiRII
Mar 4, 2003 06:54 PM
Charlie Moua
10
Oct 27, 2002 09:21 PM
