header-tech header on a gsr?
Old Nov 30, 2003 | 08:28 PM
b00sted4dr's Avatar
Default header-tech header on a gsr?
I was has a dyno of the header on a b18c1. I've searched, but only found dynos of b1c5's. And would i be able to retain a/c with these headers?
Old Dec 1, 2003 | 09:05 AM
b00sted4dr's Avatar
Default Re: header-tech header on a gsr? (96Ls4dr)
bump
Old Dec 1, 2003 | 02:01 PM
zigs's Avatar
You will be able to retain AC as far as dyno numbers wait for the results of Titanmotorsports header test they will be one of the 8 or 9 headers tested.
Old Dec 1, 2003 | 05:29 PM
b00sted4dr's Avatar
Default Re: header-tech header on a gsr? (zigs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zigs &raquo;</TD></TR><TR><TD CLASS="quote">You will be able to retain AC as far as dyno numbers wait for the results of Titanmotorsports header test they will be one of the 8 or 9 headers tested.</TD></TR></TABLE>
Thanks
Old Feb 28, 2004 | 10:41 PM
B00ST2nR's Avatar
Default Re: header-tech header on a gsr? (96gsr4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96gsr4dr &raquo;</TD></TR><TR><TD CLASS="quote">I was has a dyno of the header on a b18c1. I've searched, but only found dynos of b1c5's. And would i be able to retain a/c with these headers? </TD></TR></TABLE>
Yes, you will be able to retain A/C with these headers.
So.... anyone have the Header-Tech header on their GS-R? I got me one, but have a few questions for those who are running one in their car.
Old Feb 29, 2004 | 04:16 AM
jeremy.'s Avatar
Default Re: header-tech header on a gsr? (Skunk2nR)
i'll let you know as soon as i install my header....b16 head though
Old Mar 7, 2004 | 12:46 AM
B00ST2nR's Avatar
Default Re: header-tech header on a gsr? (ek_jeremy)
I really need to know how people are running this header with a cat. The length of the cat and what type it is.
I'm thinkin about getting a Cat with a 3" inch Inlet and 2.5" inch Outlet, since the Header-Tech header has a 3" inch collector. I just need to know how long the cat needs to be, to be able to fit.
ANY info would be appreciated. Thanks.
Old Mar 7, 2004 | 01:39 AM
jeremy.'s Avatar
just get the merge collector to go to 2.5
Old Mar 7, 2004 | 12:13 PM
B00ST2nR's Avatar
What I really need is the length between the Header-Tech header flange and the 2000 GS-R exhaust flange, so I can order a cat with a specified Length to fit in between without a problem.
Old Mar 7, 2004 | 12:19 PM
jeremy.'s Avatar
just cut the piping
Old Mar 7, 2004 | 12:29 PM
B00ST2nR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_jeremy &raquo;</TD></TR><TR><TD CLASS="quote">just cut the piping</TD></TR></TABLE>
yea I know... but then I'll have to goto a Muffler shop if I do that. I just wanna plug and play.
Old Mar 7, 2004 | 07:44 PM
na200whp's Avatar
i dont think they offer a gsr only header. the headers they offer change only w/ displacement. they are built/tuned using specific lenght tubes. it will be much longer than a stock gsr header . mine was a good 6-8 inches longer than a jdm itr header. also due to this being hand built they may vary slightly from one to another. my advise is wait till you recieve it and see if there is enough room for a cat.
Old Mar 7, 2004 | 09:06 PM
smnowell's Avatar
Default Re: (na200whp)
Hey Skunk2nR, what I did (and I think I told you this before) was get a 2.5" Carsound cat and got one of HeaderTech's 3"-2.5" conversion piece and welded it to the cat. The length of my cat is 16.25" from flange to flange. I have the 3" flange on the side where it meets the header, and a 2.5" flange on the side where it meets the exhaust piping.
As far as dynos go, I will have a dyno of my motor posted this friday with video
Old Mar 8, 2004 | 12:10 AM
B00ST2nR's Avatar
Default Re: (b16a ferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a ferio &raquo;</TD></TR><TR><TD CLASS="quote">Hey Skunk2nR, what I did (and I think I told you this before) was get a 2.5" Carsound cat and got one of HeaderTech's 3"-2.5" conversion piece and welded it to the cat. The length of my cat is 16.25" from flange to flange. I have the 3" flange on the side where it meets the header, and a 2.5" flange on the side where it meets the exhaust piping.
As far as dynos go, I will have a dyno of my motor posted this friday with video </TD></TR></TABLE>
Yea, I already have a 3" - 2.5" reduce pipe. But after looking underneath my car, it looks like it won't be able to fit with a cat unless a part of the exhaust pipe is cut off. That's why I don't wanna use the reduce pipe and instead go with a cat straight from the collector flange.
I guess I'll have to get a cat and take it to a Muffler shop to install the header and cat, to make all of it fit.
Old Mar 8, 2004 | 04:33 AM
smnowell's Avatar
Default Re: (Skunk2nR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk2nR &raquo;</TD></TR><TR><TD CLASS="quote">
I guess I'll have to get a cat and take it to a Muffler shop to install the header and cat, to make all of it fit.</TD></TR></TABLE>
You don't have space between the header and the exhaust to fit a cat? There should be enough room for a cat that is almost stock length. I remember the HeaderTech header being just about the same length as my stock header. If you have the cat and the reducer pipe, my suggestion is to get under the car and actually see just how close everything is to fitting and then measure it all up and then weld it.
Old Mar 8, 2004 | 09:24 AM
sander's Avatar
2.7(p/t)
Muhahaha your not the only one...
-sander
Old Mar 8, 2004 | 11:35 AM
smnowell's Avatar
Default Re: (sander)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sander &raquo;</TD></TR><TR><TD CLASS="quote">
-sander</TD></TR></TABLE>
yes bitch, you will have yours dynoed as well look for a post containg dyno info from me, sander, and redintheface I'll let you guys all know how the HeaderTech header does.
Old Mar 8, 2004 | 03:29 PM
B00ST2nR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a ferio &raquo;</TD></TR><TR><TD CLASS="quote">I remember the HeaderTech header being just about the same length as my stock header.</TD></TR></TABLE>
Hmm... thas wierd.
Are you serious? Right now, I'm running on a DC 4-1 header (USDM) with Stock cat. They're all bolted up nicely.
The Header-Tech header is ALOT longer than the DC 4-1 header. Especially if I add the reduce pipe.
While you're dynoing the car, take some pictures of underneath the car for us.
dunkd
Mar 24, 2007 04:17 PM
hondaboyB18C1
22
Dec 22, 2006 08:41 AM
Whitfield Inc.
Welding / Fabrication
71
Feb 16, 2005 07:04 AM
redhatchb18
25
Sep 7, 2004 02:22 AM
