Wooooooops - Some parts I forgot to install in motor!
Old Nov 30, 2003 | 06:34 PM
Fuster_Cluck's Avatar
Default Wooooooops - Some parts I forgot to install in motor!
I did my swap earlier this year.
Before dropping the 98 GSR (53k) in I changed out the following:
Timing belt
Water Pump
Valve cover gasket
oil pan gasket
Spark plug and wires
Distributor cap
Forgot about these 3 parts:
Where the hell do they go?
Old Nov 30, 2003 | 06:40 PM
vtec94civic's Avatar
the ones on the right are cam seals.
Old Nov 30, 2003 | 06:55 PM
Kendall's Avatar
Default Re: (vtec94civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec94civic &raquo;</TD></TR><TR><TD CLASS="quote">the ones on the right are cam seals.</TD></TR></TABLE>
Yep, those just might be important.
Old Nov 30, 2003 | 07:03 PM
Ok, I'll try and get them in one day.
Wherever they go, lol
dmotoguy's Avatar
Default Re: (dc231)
hopefully the old ones are still there!
Old Nov 30, 2003 | 07:06 PM
Default Re: (dmotoguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmotoguy &raquo;</TD></TR><TR><TD CLASS="quote">hopefully the old ones are still there!</TD></TR></TABLE>
Why wouldn't they be? I did the work myself and would of installed the new ones if I took the old ones out
Old Nov 30, 2003 | 07:18 PM
Kendall's Avatar
Well, that's good at least.
Old Nov 30, 2003 | 11:35 PM
sledgehammer's Avatar
Default Re: (dc231)
The bag on the left looks to be valve stem seals...btw you're gonna need 15 more of those to do the job
Mike
Old Dec 1, 2003 | 11:01 AM
myhatchrips's Avatar
Default Re: Wooooooops - Some parts I forgot to install in motor! (Hybrid93Hatch)
valve cover seals. 4 holes which are in line with the spark plugs. i doubt those are valve stem seals. i mean those should be fine since the motor is a 98. good luck
hotcivicsi
13
Feb 26, 2009 01:35 PM
theskabeater
Aug 16, 2006 11:21 AM
IVI
Jan 6, 2006 12:40 PM
PearlWhiteAccord
Jan 15, 2004 03:07 PM
plusONE jboy
Nov 19, 2003 09:37 PM
