Supercharger...INJECTORS WONT FIT? ***help***
Old Nov 30, 2003 | 03:47 PM
Jon5240's Avatar
Default Supercharger...INJECTORS WONT FIT? ***help***
hey guys im doing a install on my d16y8..and the stock injects are to big and will not fit in the hole...any ideas? the guy who sold me the supercharger doesnt really know what it would fit eh? anyway...i have y8 injectors...i looked at some LS injectors and they look like the same... do u know if the 92-97 vtec/non vtec are the same size?
-jon
Old Nov 30, 2003 | 05:40 PM
RedlinedVTEC's Avatar
Default Re: Supercharger...INJECTORS WONT FIT? ***help*** (Jon5240)
Injectors should fit fine... what did the supercharger come off of?
Old Nov 30, 2003 | 06:19 PM
rjardy's Avatar
All d series should be the same.
Rob
Old Nov 30, 2003 | 07:34 PM
Jon5240's Avatar
Default Re: Supercharger...INJECTORS WONT FIT? ***help*** (rjardy)
all the guy said was it came off of a SOHC...he wont talk to me anymore...so im not sure wut it comes off of...
my injectors are to big to fit int he supercharger... this is killin me! are all SOHC injectors the same?
Old Nov 30, 2003 | 07:38 PM
rjardy's Avatar
okay did it come off of a honda? crazy question I know..
Rob
Old Nov 30, 2003 | 07:49 PM
Jon5240's Avatar
hehe yeah it did, bolts up to my manifold perfectly..
Old Nov 30, 2003 | 07:50 PM
rjardy's Avatar
okay only thing left is PICS, can you get any?
Rob
Old Nov 30, 2003 | 08:08 PM
Jon5240's Avatar
the part in the red, is to fat to fit into the supercharger, u can fit part below it in let it go and it just falls out!
Old Nov 30, 2003 | 08:11 PM
racinskittle's Avatar
does the manifold still have to black rubber seals in?
If so, dremel them out. They'll fit then.
Old Nov 30, 2003 | 08:15 PM
Jon5240's Avatar
Default Re: Supercharger...INJECTORS WONT FIT? ***help*** (racinskittle)
thats a possiblity, but if i dremel it out, and the injector goes in...and doenst stop..then it wont be sealed...understand? hard to explain..
Old Nov 30, 2003 | 08:21 PM
rjardy's Avatar
uhmm. that part in the red square is not where the injector seals, its below that, the slimmer part. That part sticks out.
Rob
Old Nov 30, 2003 | 08:35 PM
BlueSi2k's Avatar
you probably have to take the seals from the old mani and put them in the new one or buy new ones.
Jon5240's Avatar
right below the red there is a seal...it doesnt go far enough in the supercharger.
Old Dec 1, 2003 | 06:06 AM
The-LS's Avatar
I had a similiar problem, I double stacked the black O-ring washers. I don't know it not double stacking would be okay, but it did not seem very secure to me. You might have a different problem though, because it sounds like you're saying your injectors are too big to fit in the manifold all together?
Old Dec 1, 2003 | 03:13 PM
Default Re: Supercharger...INJECTORS WONT FIT? ***help*** (Black-LS)
Hmmm, He's right. That part doesn't go in. You may have to find some decent seals that will work. But the fuel rail will help it stay in place. Just make sure it seals.
Old Dec 1, 2003 | 06:35 PM
Jon5240's Avatar
i can make the fuel fit, ill have to drill and use a custom backet or something
hmm the 2 seals amy work,,
93civciv
Feb 12, 2006 07:55 PM
ebp_dc2
Aug 19, 2005 12:57 PM
Steak84SS
Mar 20, 2005 08:44 AM
SiRkid
Aug 24, 2002 07:20 PM
