Full Race Manifold Clearance
I'm going to be starting my Turbo project later this week and am wondering about clearance problems I might have. I'm using a Fluidyne Radiator and FAL Dual Fans. I'm wondering if I have to put a different style fan in FRONT of the Radiator which may or may not be a problem for IC clearance, or do I have to buy a civic style Fan/Rad which mounts on the side? I searched for "Full Race" "Full Race Manifold" and Full Race Manifold Clearance" in both ITR and Turbo Fourm so please take it easy on me you damn flamers
well here is another thought to take in to consideration but it would not be hard to fix i read that a guy installed a full race kit on a del sol with a b18c1 and the hood wouldnt close cause of the pipes but it might be different with you cause you have a integra.
what type of intercooler do you have the kind that the compressor side of the turbo hooks up to the back of the intercooler? or do you have the kind that hooks to the sides and a pipe runs to the compressor side of the turbo?
if you have the first type the you will need to get a civic radiator and fan if you have the other style then you should be fine if the radiator and fan that you have but i may be wrong.
austrian type-R
Nov 28, 2006 01:13 PM
str8boost
Oct 9, 2005 12:00 PM
ludesleep
May 17, 2003 05:42 AM
