horn with spacro steering wheel
Old Nov 30, 2003 | 12:36 PM
boostin4door's Avatar
Default horn with spacro steering wheel
yea.. i put a sparco steering wheel into my eg, but theres no horn wire i guess cause it was in the air bag harness or something idk, but now i have no horn and have no idea how itd work the sparco steering wheel with the buttons.. theres a ground wire on the steering hub which connects to the buttons but i have no idea how to make the oem horn work with.
Old Nov 30, 2003 | 01:02 PM
salbaje's Avatar
Default Re: horn with spacro steering wheel (widebodyEg16B)
which hub are you using?? you will probably need a shoehorn to make the horn work
Old Nov 30, 2003 | 02:16 PM
hrc_385's Avatar
I got same problem, with Momo wheel and OMP hub...
How to fix this?
Old Nov 30, 2003 | 02:57 PM
Default Re: horn with spacro steering wheel (salbaje)
im using a sparco hub. its a six bolt pattern not that it makes a difference, and it is probably a really easy thing to do but you got me
vroomeo
Feb 20, 2010 08:12 PM
boostin4door
Dec 14, 2008 10:09 PM
zman
Oct 29, 2008 09:06 AM
lastlude2k1se
Feb 8, 2004 10:37 AM
743power
Mar 31, 2003 06:48 AM
