CD6 vs CD5 Suspension
Old Nov 30, 2003 | 07:46 AM
fw190bvi's Avatar
Default CD6 vs CD5 Suspension
ok....i was gonna get some JDM springs, but they only list for the CD6.....ive got a 94 EX CD5.......will these work....FYI they're espelir super active down springs
Old Nov 30, 2003 | 03:04 PM
AccordF23A1's Avatar
Default Re: CD6 vs CD5 Suspension (fw190bvi)
What year is the CD6, I have a 99 accord and ive been wondering what it is do you know, i work for a honda dealership ill see if the suspension is close to what your looking to do.
Old Nov 30, 2003 | 03:45 PM
fw190bvi's Avatar
Default Re: CD6 vs CD5 Suspension (AccordF23A1)
ok.....the CD6 is was only available in Japan....its a 94-97 (gen. 5) Accord SiR...ive got a 94 CD5 EX (4dr)
Old Nov 30, 2003 | 05:03 PM
1Quikgsr's Avatar
why was that
Old Nov 30, 2003 | 05:25 PM
fw190bvi's Avatar
Default Re: (1Quikgsr)
ok....the springs im looking at are desinged for the JDM japanese accord SiR....(94-97)....FYI...the CD6 was only avaible in japan...hence the JDM japanese accord....that ive previosuly mentioned on numerous occaions.....if ur asking WTF was it only avaible in japan....its cuz the japanese peoples dont wanna give their best hondas to us ignorant americans....because as we all know....were definatly not deserving...but once again, my ? is, will springs designes for the CD6, fit on a CD5, if u work for honda, raise your hand, and tell me if theyll fit
Old Dec 1, 2003 | 04:21 AM
iakona's Avatar
they should, but the CD6 had the H22, so they may sit a little higher than normal up front.
Old Dec 1, 2003 | 12:53 PM
fw190bvi's Avatar
Default Re: (iakona)
so in your opinion, would it be ok to get the springs, or should i get some USDM (eibach neuspeed....etc....)
Old Dec 1, 2003 | 01:05 PM
iakona's Avatar
they should be fine, just the spring rate is going to be different than the US spec ones. maybe compare the rates before you pay for them...just for reference.
Old Dec 1, 2003 | 06:54 PM
raceACCORDingly's Avatar
whats so good abot JaYdEeeM springs?
Old Dec 2, 2003 | 04:52 PM
fw190bvi's Avatar
Default Re: (raceACCORDingly)
cause JDM is the way to be.....helps to eliminate the "rice factor"
Old Dec 4, 2003 | 08:01 PM
pyrojeff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iakona &raquo;</TD></TR><TR><TD CLASS="quote">they should, but the CD6 had the H22, so they may sit a little higher than normal up front.</TD></TR></TABLE>
Why would they sit any higher? Both cars have 2.2L engines, and I dont think the H22 weighs too much more than the F22.
Old Dec 4, 2003 | 10:03 PM
Nick H's Avatar
New User
Default Re: (pyrojeff)
it's got about 30some pounds on the f22...
Old Dec 4, 2003 | 11:35 PM
CD6's Avatar
CD6
Suspension wise it's the same expect higer spring rates and different shocks! So you can install springs for CD6 on your CD5. For example: Apexi WS coilover, Tein HA,HR,CS are design for the CE1 which is the 5th gen wagon but will work on on the all 5th gen accords!
Old Dec 5, 2003 | 11:28 AM
jschmid's Avatar
Default Re: (fw190bvi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi &raquo;</TD></TR><TR><TD CLASS="quote">cause JDM is the way to be.....helps to eliminate the "rice factor"</TD></TR></TABLE>
Sure buddy. With aftermarket springs for your USDM Accord you'll at least know if they are gonna fit your car and what the spring rate is, the change in ride height, etc.
Old Dec 6, 2003 | 10:54 AM
fluxion's Avatar
amin n'rangwa edanea
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi &raquo;</TD></TR><TR><TD CLASS="quote">so in your opinion, would it be ok to get the springs, or should i get some USDM (eibach neuspeed....etc....)</TD></TR></TABLE>
nothing wrong with eibach. espelir or whatever the **** i've never heard of, however.
but yes, they'll fit. the suspension is identical, just different spring rates due to engine weight differences.
Old Dec 11, 2003 | 06:42 PM
sorry i never wrote you back but the suspension should be fine everybody is right the spring size is just a little different but its not that noticeable just make sure it all fits right before you drive it..
AdventureAccord
Jan 25, 2016 08:00 AM
hondaracer4vtec
Aug 18, 2008 10:24 AM
mistah lude
Aug 1, 2007 04:06 PM
EL-Driver
Aug 14, 2002 09:03 PM
