does the engalls front camber kit fit...
does the engalls front camber kit from a 97 integra fit my 00 ek? my friend has them on his car and is thinking of selling them. just wanna know if they fit or not?
Why do you need a camber kit?
I wouldn't bother to waste the money unless you autocross/HPDE and need to dial in more negative camber.
Don't worry about camber wear on your tires. Improper toe eats tires much more than improper camber does.
Just lower your car and then go to an alignment shop and tell them to set your toe to zero. You shouldn't see much if any uneven tire wear, as long as you rotate the tires as often as you should.
E36 Guy
16
Apr 7, 2006 09:58 AM
