CRX rear disc brakes on EG??
What about EH chasis? (I'm assuming yes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92b16vx »</TD></TR><TR><TD CLASS="quote">Simple answer, depends if it is a 88-91 no, if it s a 92-97 (otherwise known as a Del Sol) yes.</TD></TR></TABLE>
a del Sol is not a CRX, i am talking about a 90-91 CRX Si setup on a 92-95 CX. i dont why you cant. i mean you can put a 90-01 teg **** on a CRX no problem, and you can put the teg stuff on the EG also...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbohf »</TD></TR><TR><TD CLASS="quote">i sware i seen a magazine or somethign that said they used CRX brakes on a EG.....</TD></TR></TABLE>
I've heard the splindles are the same, and will bolt up to your trailing arms, but that the trailing arms were a little different. I haven't compared them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mxpx035 »</TD></TR><TR><TD CLASS="quote">so del sol brakes will fit on a eg because i can get a set for free but i didn't think they would work</TD></TR></TABLE>
Yes, that's what I had before I swapped to the 99 five doors (Europeon model), which by the way are another direct bolt on.
YES!!!EF(88-91) rear disc swap works on an EG!i've done it before.EF/EG/EK/DA/DC all interghange.of course,you can't use the EK LCAs on any other car,but everything else swaps.
chris
chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris »</TD></TR><TR><TD CLASS="quote">YES!!!EF(88-91) rear disc swap works on an EG!i've done it before.EF/EG/EK/DA/DC all interghange.of course,you can't use the EK LCAs on any other car,but everything else swaps.
chris</TD></TR></TABLE>
So, everything but even the trailing arms fit? Good info.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris »</TD></TR><TR><TD CLASS="quote">the sus and flywheel will work.if you're trying to use the Da intermediate shaft in an EG hydro setup,it won't work.
True, although I'd weigh the DA versus EG flywheels to see if there's any weight difference before swapping one for the other.
I have a DA rear disc set up on my EG.....works fine......everything bolted up TA and all.....I used SRR LCA 's and you do need to change your toe arm for the DA shorter one or get and adjustable one!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92b16vx »</TD></TR><TR><TD CLASS="quote">Simple answer, depends if it is a 88-91 no, if it s a 92-97 (otherwise known as a Del Sol) yes.</TD></TR></TABLE> wrong.
the trailing arms, compensator arms and upper control arms with a rear disc brake swap from a CRX will and are required to bolt it to an EG or even an EK !
the CRX lower control arms will work on EGs, (NOT on EK's) but some ('88?) CRX's had the ITR-style lower control arms which require ITR style rear shocks.
CRX/DA/DC2(non-R)/EG rear disc brake setups are prettymuch identical except the parking brake cable may be different lengths and can be run thru a different path to make up or give length to route it wisely.
you guys are funny....... so here is a recap for rear disc swaps to an EG....
trailing arms = YES,
comp. arm + uca = YES,
rear lca's = maybe NO (DA=no, crx/civic without swaybar may be not desired or shock mount on lca may require different shocks)... otherwise maybe YES.....
the inter shaft and flywheel were extras, accually the DA had a B16A in it. the engine threw 3 rods!!!!! car was missing the head when it got to the JY and i just missed out on the S1 tranny
will the master cylinder work on an EG? a friend said he thinks it mounts backwards...
anyone need a B16 intermidate shaft or flywheel? PM me....
