nitrous install question about tps and 12 volt accesory source of power ...
ok im installing a zex wet kit on my 97 ek and the only thing i have to do is hook up the white wire from the nirtous management unit to the output voltage lead on the tps , where is the output voltage lead, is it a wire or a box? if a wire what color and do i just splice it onto the output voltage ??? and, i have to fine a 12 amp soucre of power under the dash, what can i use for this?
thanks alot
thanks alot
Tap the middle wire on the TPS for the ZEX kit.
Tap any 12v source that comes on with the key for the switch. You'll need a volt meter or you can tap into the cig lighters red wire if your desperate.
Also don't forget to search, there is tons of threads on this.
thanks, on the throttle body there are two black boxes, one on the top of the tb and one on the side of it, the one on the top says map assy. sensor and the other i can't read because it'on the back side of the tb , attached to both black boxes there are 3 wires.... which box and wire do i use?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preacherboy »</TD></TR><TR><TD CLASS="quote">on the throttle body there are two black boxes, one on the top of the tb and one on the side of it, the one on the top says map assy. sensor and the other i can't read because it'on the back side of the tb </TD></TR></TABLE>
The TPS is the sensor on the side of the TB.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preacherboy »</TD></TR><TR><TD CLASS="quote">which box and wire do i use? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt »</TD></TR><TR><TD CLASS="quote">Tap the middle wire on the TPS for the ZEX kit.</TD></TR></TABLE>
VolkswagenWHO!!!
Jan 4, 2006 01:34 PM
team2n1hatch
Jun 26, 2004 11:19 AM
TABIAS
Nov 29, 2003 03:58 PM
C4wrx
Jan 28, 2002 05:41 AM
