gas?
i have a lil prob
i have way too much gas entering my 89 accords carb do any of u have a service manual that shows how to lean out a carb?
also i need to know how long i have to replace a catilityc converter before i blow my engine
my looser bro told me to bust it out and its caused nothin but probs since
you getting flooded with gasoline when you at idle or what?
on some car there's a little adjustment screw on the carb.
I never work on one tho', at lease not a honda carb.
Have you checked the float levels? If you don't have one, get a manual and check the procedure. It boils down to:
1) Park the car in a level place
2) pull the covers for the float sight glass(es)
3) there is a mark on each glass indicating where the gas level should be
4) if it's high, there is a screw adjustment for each float (varies per carb)
You NEVER should have messed with the converter
Yeah, it's easy for the float valve to stick open, float bowl overfills & spills through the vent into the throat.
Back in the day... (guess I'm getting old). When injection was becoming popular everybody said "now you'll never be able to work on your cars again because injection is so complicated"...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hideurgurls »</TD></TR><TR><TD CLASS="quote">... i need very precise intructions on where the screw is and how to turn how far so on
ty
</TD></TR></TABLE>What you need is a repair manual for your car. I've done it many times on a Hitachi DAF328 but that was a '72 Datsun. Each carb is different.
It's not about turning a screw. It's about taking the carb apart, cleaning it, & putting some new parts in.
ty
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hideurgurls »</TD></TR><TR><TD CLASS="quote">yea apperntkly im wrong its a throttle body carb and there is no float jus and injector inthe throat if that helps guys
What model do you have? DX, LX or LX-i?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hideurgurls »</TD></TR><TR><TD CLASS="quote">its a dx
That means it has a carburator. Three problems come to mind to cause to much fuel to be metered.
A bad float.
needle valve
choke pull-off diaphram
A bad float.
needle valve
