No compression....
Couldn't really find anything in a search and just wondering if this is common, or did it just die. I have zero compression in number 3 cylinder all of a sudden. The car is a stock 90 LX with 172, on it. It's not noisey or anything, just missing.
If you're sure you did it right, then you likely messed up a valve or the ring gaps are all aligned. Other possibilities include a badly worn cam lobe(s), or really messed up valve lash adjustments.
How did you determine you have zero compression, by a compression test or what?
Seems like it would be really hard to actually get ZERO. If you forgot to install rings completely, you'd have to get 10 or 15 psi. Even a bent valve. It has to be something really serious, like the valve being completely gone or a big hole in the top of the piston.
Or maybe a gauge that's not working right??
Should have been more specific, not zero no, it was around 15 or so. When I was driving it before, over 4500 or so it would seem to miss every once in awhile then it just died all together. I was thinking valve problem but it isn't noisey, maybe lash then?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">Maybe a leakdown test to narrow down the problem? (I guess a burnt exhaust valve.)</TD></TR></TABLE>
burnt? you mean bent?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick H »</TD></TR><TR><TD CLASS="quote">
burnt? you mean bent?</TD></TR></TABLE>
No, but that's a possibility too.
Has the timing belt ever been broken on it?
what exactly do you mean by burnt? and most times that a timing belt breaks, well, you'll be missing chunks of valves in the combustion chamber...i think that would be an obvious problem...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick H »</TD></TR><TR><TD CLASS="quote">what exactly do you mean by burnt? and most times that a timing belt breaks, well, you'll be missing chunks of valves in the combustion chamber...i think that would be an obvious problem...</TD></TR></TABLE>
Never seen a burnt valve, huh. The best way I can explain it: it looks like the one small spot on the edge of the valve got hit but a cutting torch. One way it happens is when a piece of carbon gets between the valve and the seat causing a hot spot.
Remember I said it was just a guess.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammed2K1 »</TD></TR><TR><TD CLASS="quote">... I was thinking valve problem but it isn't noisey, maybe lash then? </TD></TR></TABLE>Another way to get a burnt valve is if your valve lash is adjusted too tight. Then when the engine's hot the valve doesn't quite close.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick H »</TD></TR><TR><TD CLASS="quote">what exactly do you mean by burnt?</TD></TR></TABLE>
How about a couple pics? Just got the ok to tear this one down today.
lol forgat it got to be a valve ore a piston ring. my car viabrated a lot from time to time when ii came out of the highway then it would run good till finaly it got fucked up andi had to buy a used head engine which by the way forgat to change the valve seals and now burns oil in the morning like ****. i smoke the whole block
I wasn't even thinking burnt valve, probably what it is. The cat broke apart and clogged the exhaust and I was too lazy to fix it, being it's my beater, even though it's the only one running, that sux. Guess I have to get off my *** and finish the civ. Chris
nemesis25
Jan 12, 2015 04:17 PM
