Anyone using the b16 Rod/Supra pistons from turbopanda in their D series?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PureCRXtasy »</TD></TR><TR><TD CLASS="quote">
This is almost getting to the point that it needs a FAQ.
Nathan used these in a d16y8. The d16y8 has a 75mm bore and a 90mm stroke length. Take the engine you plan to put them in and find out if that matches or not.
that will tell you if they'll fit.
From the research I've done, these should work in all of the following:
ZC (d16a8)
88-91 SI (d16a6)
96-00 DX (d16y7)
96-00 HX (d16y5)
92-95 Si/EX (d16z6)
96-00 EX (d16y8)
In their current state, they don't appear to work in the rest of the d-series engines because they are 75mm x 84.5 These include:
88-91 HF (d15b6) (but why would you want to anyway?)
88-91 DX/LX (d15b2)
92-95 CX (D15B8)
92-95 DX (D15B7)
92-95 VX (D15Z1)</TD></TR></TABLE>
The supra pistons are forged, and have lower compression, after reading... it looks like the compression will be close to 9.0-9.5...
THEY FIT so dont argue. just want to know if anyone actually use's this system, because i plan on buying it asap.
I want to buy package #1.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbopanda »</TD></TR><TR><TD CLASS="quote">package 1:
6 used Toyota 1G-GTE pistons ($170) + new piston rings - pack of 6 ($70) + 4 second-hand B16A
connecting rods ($95) + machine work ($65) + shipping costs ($120) = $520 total
package 2:
4 brand new Toyota 1G-GTE pistons ($300) + new piston rings - pack of 6 ($70) + 4 second-hand B16A connecting rods ($95) + machine work ($65) + shipping costs ($120) = $650 total ($800 if you would like an additional 2 brand new Toyota 1G-GTE pistons)</TD></TR></TABLE>
[b]MUCH more info on the original post here: https://honda-tech.com/zerothread?id=267641&page=1
Anyone? anyone at all using this setup in their D series?
ZC (d16a8)
88-91 SI (d16a6)
96-00 DX (d16y7)
96-00 HX (d16y5)
92-95 Si/EX (d16z6)
96-00 EX (d16y8)
88-91 DX/LX (d15b2)
92-95 CX (D15B8)
92-95 DX (D15B7)
package 2:
i would also like to know if anyone is using these. i thought about using this setup before.
If I was going to build a D i would deff go with this setup. Turbopanda is a good guy to, he will do you right. that sounded bad but you know.
Rob
Rob
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjardy »</TD></TR><TR><TD CLASS="quote">im turbo panda, he did it
Rob</TD></TR></TABLE>
Where has he been lately?? Did he ever get that Evo he wanted??
Damn, am I the only one that used this setup????
I ran these in my D and tuned it to 250WHP. Unfortunately I had to take them out because when I installed the pistons I didn't install the oil control rings properly. The oil control ring cracked and then scarred my cylinder walls. But I assure anyone who is interested in this setup that the cause of failure was directly my fault, not the components.
When I ordered the setup I ordered 6 pistons so I am going to put them into another Z6 bottom end. My goal is 300+WHP daily, on nathans combo.
Nathan is a good guy and you can definately trust him to deal with. I think that the reason you don't see him online is cuz he got an EVO and moved out of the honda scene.
I'll never see a B-series motor, when I get a spare A6 block I'm gonna start saving for that set-up. Low compression isn't nearly as bad as everyone THINKS ( not "KNOWS", "THINKS" ).
My 8.4/1 compresion Z6 bottom, A6 top has full boost at 3700rpms with factory 1'' DX exhust piping from the cat back and a 2 1/4'' DP...
What are the valve diameters of the Supra motor and the valve pocket diameters of the supra piston?
What is the compression height of the supra piston?
What is the pin diameter?
I want to get this on paper from a mathematic point of view and for that I will need all the factors listed above.
Also, has anyon bothered to check the valve angles to see if they are even compatable?
There are many variables that would have to be common for this to work PROPERLY
If someone can supply the above requested info Ill tell you the probability of this combo.
Just because it runs doesnt mean it runs properly or efficiantly.
His calculations for compression ratios are way off, I just noticed that by flipping through a few magazines. The compression heights are way taller than the D series pistons making compression a lot higher than what he calculated. Also, the valve diameters are much bigger from what I remember and the angles are nowhere near the same.
If I can get all of the factors Ill show everyone the begining to end in terms of spec comparisons and calculations.
I want to make somethign clear, Im all for this. If it works GREAT! Im in the porcess of building a boosted D16Y8 for my GF and would love to find a budget solution to internals. I had originally planned on using LS rods and a set of JE's. If this works Ill look into this.
He diffeence in compression height looks to be solved with the 3mm shorter B16 rods, it might actually over compensate. I wont know though untill I get all the specs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">4 used pistons ($113.40) + 4 new piston rings ($46.60) + 4 connecting rods ($95) + machinework ($65) + shipping costs ($95) = $415 total.
6 used pistons ($170) + 6 new piston rings ($70) + 4 connecting rods ($95) + machinework ($65) + shipping costs ($95) = $495 total</TD></TR></TABLE>
Hmmm
I can get JE's at WD price (Friend of mine is a dealer) and I have several sets of LS rods laying around. Its cheaper for me to go with JE's and LS rods.
Ill still help you guys out with the numbers if someone can post up the specs.
Hmmm
i looked at my stock p28 piston and the valve reliefs appear to be almost identical to those, the only difference being the notches on the side of the piston from the valve relief (dont know how to explain it better)
Why dont you use Suzuki Vitara pistons? Theyre also forged and will be cheaper than the Supra pistons(even brand new). They are also floating style pistons so that mean that u can put the rods in there w/o having to pay for a machine shop(which will save you even more money)This is what i am doing.
The only thing is that oppsed to the Supra pistons, the Suzuki Vitara pistons will yield lower compression.
8.5:1 on Y7 stock head, slightly higher on Y8 heads(around 8.7:1)
If you want higher compression the u could Mill the head.
Suzuki pistons $146 Brand new set(without a hook up YO)
Hasting Rings(For honda D series piston) $60
4 connecting rods(95)
No machining needed. Total $295
They drop right in any Dseries 75mm block
I got these pistons and rings through a hook up and even with buying Brand new Eagle rods I didnt spend more than $425 on my piston & rod combo.
