can i put a f22 crank in my h23
Guest
Posts: n/a
i recently spun a rod bearing in my 95 prelude se i was just going to put a h23 short block in mines place but after looking it over ive been thinking of getting a new crank and the one rod then all new bearings will this work? i can get a f22 crank for 75 buck instead of 125 for the h23 but they have the same part #. my question is can i fix my motor this way and can i use this crank?? thanks any help is welcome
Modified by spanishlude at 8:27 PM 11/28/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 lude »</TD></TR><TR><TD CLASS="quote">I am almost positive you can! Talk to satan srv. he has an f22b crank in his all motor h22 setup right now and it seems to be fine.</TD></TR></TABLE>
they have the same mains
like you said it's the same part number, yes get the f22 cheaper and more abundant than the h23 engines, btw the f22 crank and rods is what I'm using on my engine to achieve that extra displacement. also fyi the f22/h23 cranks weight 35 lbs and the h22a1's 39lbs
projectef
Sep 26, 2007 04:02 PM
