Left Low Beam WENT OUT????
OK my car was parked b4 i parked it both low beams where working, turned the car on turned on head lights and i get no left low beam checked blub, blub is good , checked fuse, fuse is good any ideas this is the 1st time this has happenend
nope didn't touch the blub the headlights where working fine when i parked it and "there wasn't any cars in front of me or any solid objects when i parked it" but the blub is good so any other ideas?
TMO WHAT UP* HOME SLICE
what's happening folks! So you are saying that the bulb WORKS when the car is not on and doesn't work when it is turned on??? If so I never heard of that. hope that some one helps you.
i actually had this same exact problem on the same headlight on the same bulb. all i did was disconnect the harness from the bulb and reconnected it, and then kinda jiggled it around... i guess it was a loose connection? hope it myte help
haha same thing happened here... it came on after i had unlocked the little lock thing that holds the headlight in and pulled it outa the headlight... damn Piaa Super Whites are bright!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kisses_89_HB »</TD></TR><TR><TD CLASS="quote">fixed it i slaped the blub against the windshield wiper container </TD></TR></TABLE>
umm...umm...
talk about being a caveman to fix things...do you punch your computer when it freezes?
umm...umm...
jonny11844
Feb 23, 2014 05:14 PM
jimboek
Apr 30, 2007 05:22 AM
cr00klyn718
Apr 9, 2002 02:45 PM
