Hondata and the base maps question.
I'm going to put in my tuning appt. soon. But I need to make sure everything is working ok. I had my hondata tuned to 8lbs last year and now I've got forged pistons and rods in my block now, I plan on running 12psi daily (i have a 3 bar). I want to make sure my boost controller is working right before I bring it in. The wastegate is set to 8lbs so I have yet to really use the boost controler. I want to test to make sure that I can bring the controller up to 9 lbs just to make sure it is doing its job, and then set it back to 8 or off. This is where my question comes in.
Since my tune was only done at 8 lbs, are there any fuel and timing tables past the 8 lbd mark? Is it part of the base map? Are they rich or lean if anything is there? Is it safe to test it out?
Thanks!
Modified by Aeka GSR at 4:07 PM 11/28/2003
Thanks!
phaphon
Sep 12, 2011 10:57 AM
GOLDBERG
Apr 29, 2003 09:03 AM
