need help to lower compression
i will apperciate some help,,,, i have crx 91 sohc si. what can i do to make the compression lower as posible? because i want to run a turbo. i like to stay in lower budget, i like to get around 200 hp at the wheel. which turbo would be the best the t3 or the t25 turbo?
To lower compression. First remove the airfilter. Second find a dirt lot and do lots of dusty donuts, taking care to drive through the dust as much as possible. _OR_ take a handful of sand and dump it into the throttle body while at full throttle. Low compressionwill quickly follow.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cstem »</TD></TR><TR><TD CLASS="quote">To lower compression. First remove the airfilter. Second find a dirt lot and do lots of dusty donuts, taking care to drive through the dust as much as possible. _OR_ take a handful of sand and dump it into the throttle body while at full throttle. Low compressionwill quickly follow.</TD></TR></TABLE>
who lets these people in???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mateencrx91 »</TD></TR><TR><TD CLASS="quote">i will apperciate some help,,,, i have crx 91 sohc si. what can i do to make the compression lower as posible? because i want to run a turbo. i like to stay in lower budget, i like to get around 200 hp at the wheel. which turbo would be the best the t3 or the t25 turbo? </TD></TR></TABLE>
Thoes rods arent ment to handle 200 hp at the crank, and you want 200 at the wheels, so according to my calculations with a 15% drivetrain loss you will have 230 at the crank. not good on a stock engine, wont last more then 2 months. run lower boost or reinforce the rods at least.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_guy_83 »</TD></TR><TR><TD CLASS="quote">
Thoes rods arent ment to handle 200 hp at the crank, and you want 200 at the wheels, so according to my calculations with a 15% drivetrain loss you will have 230 at the crank. not good on a stock engine, wont last more then 2 months. run lower boost or reinforce the rods at least.</TD></TR></TABLE>
If this were 2 years ago i would totally agree with that statement, but over the last 8 or so months there have been numerous people running higher numbers on bone stock a6's... Ive seen at least 2 that are runng over 14psi and making well into the 230-240hp to the wheel range. Its all about tuning and fuel management...running high boost on a bone stock a6 thats tuned is fine...but u detonate once and ur done.
yz125rider21
Jan 20, 2006 03:03 AM
