p30 pistons & ls rods
dude you talking about ls rods! which were made for b18a/b's from the factory so why the **** would u have to mess with the rod to fit in thier OEM set up?? pistons need to be shaved a lil to accepct the ls rods. there is your confirmation
b16a and b17a pistons fit ls rods fine the small end of the b16a rods are even the same dimensions as the ls stuff. The gsr/itr/ctr stuff needs to be machined to fit. I've put alot of lsvtec together with b16a pistons.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tnsxsear1 »</TD></TR><TR><TD CLASS="quote">Dont listen to these guys, They will fit with no modification. Just take them to a machine shop and have them pressed. I have the p30's in my ls/vtec also. -pj</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_KJ »</TD></TR><TR><TD CLASS="quote">b16a and b17a pistons fit ls rods fine the small end of the b16a rods are even the same dimensions as the ls stuff. The gsr/itr/ctr stuff needs to be machined to fit. I've put alot of lsvtec together with b16a pistons.</TD></TR></TABLE>
thanks
thanks
hey awhile back when i did a LS-R conversion for my project the machinist had to machine down the small end of the rod to fit the First gen B16A piston. I told him it should fit and he brought the piston and the rod to show me...the rod wouldn't slide into the piston so the rods had to machined down to fit...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisCNL »</TD></TR><TR><TD CLASS="quote">hey awhile back when i did a LS-R conversion for my project the machinist had to machine down the small end of the rod to fit the First gen B16A piston. I told him it should fit and he brought the piston and the rod to show me...the rod wouldn't slide into the piston so the rods had to machined down to fit...</TD></TR></TABLE>weird, i have b16a pistons on my ls rods w/o NO modification.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itec311 »</TD></TR><TR><TD CLASS="quote">I too have run p30's on ls rods with no modification.
Misinformers
So do I!
Misinformers
</TD></TR></TABLE>So do I!
DOMKID
Feb 25, 2004 01:32 PM
