My drivers wheel locks up really bad, under braking...
Old Nov 28, 2003 | 01:14 AM
91hondacrx's Avatar
Default My drivers wheel locks up really bad, under braking...
I can be driving around and if i ever need to come to a stop quickly and i do not smash on my brakes, but i apply a generous amount of pressure, the front drivers wheels almost always wants to lock up, even if it is a stop that i have been able to do before without a problem.
I just installed my tein ha dampering kit a couple weeks ago, and then my front ingalls camber kit, before the camber kit it did not do this as bad. But now that the camber kit is on, it is awful. I know my alignment is off, could that be making my braking THAT bad? Just curious to see if any of you guys have any input.
Dunno if it matters for this situation, but i am running the 175/60?/13 wheels and tires, nothing performance oriented, just regular tires.
Thanks,
Matt
Old Nov 28, 2003 | 05:58 AM
dilbert's Avatar
Default Re: My drivers wheel locks up really bad, under braking... (91hondacrx)
well the alignment could do it if one side(passengers was pretty close to correct) and the drivers side was quite a bit off. That would give you better traction with one side and less with the other, hence the lock up. But I am not sure on that, so yea, and get an alignment!
Old Nov 28, 2003 | 07:53 AM
88turdbucket's Avatar
it almost sounds like you have a bad caliper
Old Nov 28, 2003 | 08:02 AM
onePOINTsix's Avatar
Default Re: My drivers wheel locks up really bad, under braking... (88turdbucket)
yep bad caliper is more then likly the case, replace it and the problem should go away, do it soon because my friend had a bad caliper and it made the pads drag intill the point where their was no more pad and the piston was rubbing on the rotor
Old Nov 28, 2003 | 08:06 AM
WindyIce's Avatar
Default Re: My drivers wheel locks up really bad, under braking... (Sideout)
has to be the calipers. I had the same problem . My right side would sieze up bad and not let go. got one from the junk yard and was rdy to go :D
Old Nov 30, 2003 | 04:19 PM
91hondacrx's Avatar
Default Re: My drivers wheel locks up really bad, under braking... (WindyIce)
i dont think that would be it(caliper), because i have had a locked caliper on my car before, actually 2 of them, it was awful. bad smell, rotors were new before i put them on too. so where the rotors, my damn brakes were smoking, my wheels burned my hands just to take them off, and good lord, it took forever to get the different calipers on as hot as everything was.
Matt
Old Dec 3, 2003 | 06:55 AM
nykutz's Avatar
check your mastercylinder or you booster i had the same prob and i had to change both and pro fixed so see if thats it
Old Dec 3, 2003 | 10:03 AM
91hondacrx's Avatar
Default Re: My drivers wheel locks up really bad, under braking... (nykutz)
I just replaced the master cylinder about 1500 miles ago(new motor). And everything has been fine until after i put on the camber kit. I think i may have the car high enough that it would not matter to much for me to pull off the camber kit for the winter. Oh, also if i did upgrade the brake booster, which would be a good one to choose. I likes to have GREAT brakes.
Thanks,
Matt
Old Dec 3, 2003 | 08:58 PM
nykutz's Avatar
if you wanna swap the master use a1990- 91 acura integra booster and master only thing is that u need to make a new line and fitting to fit the master just one i belive its the line closer to master, i did it and brakes stop lovely but i also did the acura front disc front conver on my 1990 si
xunkn0vvnx
Oct 5, 2005 10:16 AM
Spectrum24x
Aug 12, 2005 11:59 AM
Ross2852
Jul 28, 2005 06:06 PM
verbal
Nov 4, 2004 10:16 AM
PatrickGSR94
Feb 28, 2002 04:49 PM
