Cold air intakes rule! Dyno proven!
Old Sep 15, 2001 | 02:55 PM
HX_Guy's Avatar
Default Cold air intakes rule! Dyno proven!
Heres a direct, back-to-back comparrison of a 3" "normal" intake vs a 3" cold air intake.
HUGE gains from 4100 to 5300 RPMs...as well as 2-3 HP and TQ increase above 5300!
Blue = Cold air intake
Red = Normal intake
Old Sep 15, 2001 | 03:53 PM
Mike95lude's Avatar
Default Re: Cold air intakes rule! Dyno proven! (HX_Guy)
damn you must have a lot of money always dynoing and modding your car
Old Sep 15, 2001 | 03:57 PM
Vazquez911's Avatar
Though what you're are not taking into effect... is how "good" is the factory intake? I.E. does it flow as BADLY as the stock GSR??? Or as GOOD as the stock ITR? Nonetheless, a CAI DOES help... but always note, gains vary tremedously...
Hell, for a gain... you should have seen what an intake did for a bud LT1. ick...
[Modified by Vazquez911, 6:57 PM 9/15/2001]
Old Sep 15, 2001 | 04:21 PM
Muglit's Avatar
New User
Cool you finally got around to testing it. I guess I'll be keeping the extensions on.
Keep up the good work you are helping me out alot
Old Sep 15, 2001 | 04:25 PM
HX_Guy's Avatar
Default Re: Cold air intakes rule! Dyno proven! (Mike95lude)
Heh....its called "always being broke"
I think its a damn addiction..I should get help
I had $70 to my name..and I spent $50 on the dyno..now I got $20 till pay day.
Old Sep 15, 2001 | 04:42 PM
Lyonel's Avatar
Nice
I guess you did this test with back to back dynos. Did you wait for the other intake to warm up before you performed the 2nd run?
Old Sep 15, 2001 | 04:45 PM
HX_Guy's Avatar
Default Re: Cold air intakes rule! Dyno proven! (Lyonel)
Run .028 (cold air intake) was the 6th run of the day.
Run .029 (normal intake) was the 7th run of the day.
They were done about 90 seconds apart.
Old Sep 15, 2001 | 06:24 PM
ezark's Avatar
funny, because i did the same exact test- and it was about the same results. the cold air intake had a big leap of hp on the low end side; however, over all the short ram made 2whp more on the peak. the cold air intake was only 2.5" -
Old Sep 15, 2001 | 06:32 PM
JDM_DOHC_SiR's Avatar
New User
Nice Job Keep Dyno'n for us your saving a lot of us money j/k Good numbers between the 2 runs
Old Sep 15, 2001 | 06:39 PM
HX_Guy's Avatar
Default Re: Cold air intakes rule! Dyno proven! (krazE)
No no...here's a better picture
RedlineMotive
15
Oct 7, 2009 10:22 AM
deerman2701
Apr 30, 2008 04:33 PM
nsxxtreme
Honda S2000
Mar 15, 2002 05:01 PM
HX_Guy
Sep 16, 2001 10:54 AM
