OBD 0 to OBD 1 Injectors Removing Injector Resistor Box
Old Nov 27, 2003 | 07:15 PM
crxhybrid1320's Avatar
Default OBD 0 to OBD 1 Injectors Removing Injector Resistor Box
This was an 91 Integra LS OBD 0 and has a JDM GSR engine OBD 1 conversion with wiring converter and OBD 1 P72 ECU. I heard that if you use the OBD 1 GSR injector which are saturated injectors you need to remove the peak and hold resistor injector box.
To do this just cut the five wires off the green conector and solder all five together right? That what the guy told me that sold the OBD 1 converter for the ECU!
Old Nov 27, 2003 | 07:36 PM
Turbogixxer's Avatar
Default Re: OBD 0 to OBD 1 Injectors Removing Injector Resistor Box (crxhybrid1320)
Yes, you should have four wires that are the same color and one that is different. If you solder them all together it will work.
I hope that helps.
Old Nov 29, 2003 | 02:56 PM
Default Re: OBD 0 to OBD 1 Injectors Removing Injector Resistor Box (turbogixxer)
Thanks
Jap_Spec_Imports
Mar 15, 2009 01:21 PM
4thgenhtch
Jan 31, 2006 12:44 PM
maximedx
Jul 17, 2005 08:14 PM
paybac4223
Oct 13, 2004 12:37 PM
RedRunner
Mar 28, 2004 11:23 AM
