throttle bodies
Old Nov 27, 2003 | 06:51 PM
streetracinghn's Avatar
Default throttle bodies
i saw a crx the other day with ind. throttle bodies. what is the purpose of this. can it be done on my 91 accord what is involved in this process
Old Nov 27, 2003 | 07:06 PM
Crono139's Avatar
Default Re: throttle bodies (streetracinghn)
I've never seen it done on an F22, but that doesn't mean it's not impossible.
Basically, with the ITB setup, instead of having just a single TB, you now have quite a few of them, depending on the number of cylinders. Right after installation, you will notice that your idle is changed for the better. Throttle response is now better because the volume of air entering the intake manifold is decreased. Some gains in low to mid-end power will also be noticed.
Old Nov 27, 2003 | 08:18 PM
2+2=5's Avatar
Default Re: throttle bodies (Crono139)
it's the set up for high rev'ing N/A motor set up.
but you gonna have to tune and modify the fuel map for the motor.
it's getting cheaper and cheaper now, there's kit for it which run about 3000buck
or your can weld youself a set with motorcycle throttle bodies
unusual71
11
Jan 20, 2010 09:01 AM
BigBlock22
Sep 30, 2009 12:44 PM
y-49
Feb 15, 2009 07:08 PM
Creator
Nov 14, 2005 09:19 AM
fliP
Dec 30, 2004 10:28 AM
