sunroof inserts?
ive seen these available for the crx/efs but are they any manfactured one that you can buy? i can only imagine how much weight it would take off. and if not then how hard would it be to make one? just a shot in the dark here but would just need some CF cut to size sealant and a way of securing it down? or would it be more dollar per pound affective to just weld in a sheet of aluminum? thanks!
well if you just wan an insert I think someone was working on one of those...mine would be an OEM replacement but it would be applicable as a plug as well I would think
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4bidden »</TD></TR><TR><TD CLASS="quote">There is a post on PO that says raceplates.com will make one for the 4gen, cost is outrageous for a plug though. </TD></TR></TABLE>
That's what I was thinking of. How much were they asking?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shaiboyr »</TD></TR><TR><TD CLASS="quote">Would the sunroof still work if the CF insert was used?</TD></TR></TABLE>
no the idea is to remove the entire sunroof then cover it and seal with a sheet of CF, dropping +50lbs from the highest point on the car
