front end vibrates bad after swap
Old Nov 27, 2003 | 03:36 PM
HatchBox's Avatar
Skoobie no more...
Default front end vibrates bad after swap
what could it be?
it only vibrateds under acceleration
if i let off the gas it doenst do it....when i brake it doenst do it...what could it be?!
searched and found it could be axels, or maybe inner bearings in the tranny...
would bad balljoints cause this?
Old Nov 27, 2003 | 04:01 PM
tdaccord's Avatar
Default Re: front end vibrates bad after swap (ind3ciso)
lugnuts tight? tires balanced?
Old Nov 27, 2003 | 04:21 PM
Targa250R's Avatar
be professional
What swap, what car, and what axles?
Old Nov 27, 2003 | 04:42 PM
HatchBox's Avatar
Skoobie no more...
Default Re: front end vibrates bad after swap (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">What swap, what car, and what axles?</TD></TR></TABLE>
b16, 90 civic hatch and the axles hmotorsonlne sent me
Old Nov 27, 2003 | 04:43 PM
Josh717's Avatar
did you take the rings outta the hub?
HatchBox's Avatar
Skoobie no more...
Default Re: front end vibrates bad after swap (tdaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tdaccord &raquo;</TD></TR><TR><TD CLASS="quote">lugnuts tight? tires balanced?</TD></TR></TABLE>
yes and yes
Old Nov 27, 2003 | 04:49 PM
Fobtions's Avatar
did u remember to bend the back crossmember where the L bracket is.
Old Nov 27, 2003 | 04:57 PM
HatchBox's Avatar
Skoobie no more...
Default Re: front end vibrates bad after swap (Fobtions)
why what would that do?
Old Nov 27, 2003 | 06:11 PM
JonGP4's Avatar
its your axles, one must be warped or bent.. if its only under accleration.. its a bad axles.. i'm 99% sure
Old Nov 27, 2003 | 06:14 PM
HatchBox's Avatar
Skoobie no more...
Default Re: (JonGP4)
it couldnt be the rear motor mout hitting the rear crossmember. as i didnt bend the lip down
Old Nov 28, 2003 | 12:18 AM
xt_out's Avatar
i was kind of thinking motor mounts possibly, but most likely axels, as said.
Old Nov 28, 2003 | 12:33 AM
crx98's Avatar
Default Re: (tuo_tx)
did you remember to place spacers on your motor mounts? mine vibrated because it was hitting the frame
Old Nov 28, 2003 | 01:58 AM
LudeEFv2.4's Avatar
My old title sucked.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ind3ciso &raquo;</TD></TR><TR><TD CLASS="quote">
b16, 90 civic hatch and the axles hmotorsonlne sent me </TD></TR></TABLE>
you need to make new axels using your old ones and the ones you were sent. take both sets to an axle shop, fit the inner's of the b16 axels to the outers of your stock axles, and make sure they are completley re-manned. that ought to do it.
Old Nov 28, 2003 | 04:48 AM
jolt-tsp's Avatar
Default Re: front end vibrates bad after swap (LudeEFv2.0)
Check axles and motor mounts. My friend had a shakey front end, but the poly inserts for the motor mounts helped a lot.
Old Nov 28, 2003 | 05:26 AM
HatchBox's Avatar
Skoobie no more...
Modified by ind3ciso at 8:34 PM 11/29/2003
Old Nov 29, 2003 | 04:34 PM
HatchBox's Avatar
Skoobie no more...
well its not the axles not the rear crossmember...but its inside the tranny...when i put my finger inside the tranny it wiggles...and when i put the axle in...it goes in and out...
Old Nov 30, 2003 | 06:24 AM
HatchBox's Avatar
Skoobie no more...
time for new tranny.
jdm12345
Jul 26, 2007 12:08 PM
white_db8
Jun 17, 2007 08:01 AM
Silspeg6
May 30, 2007 10:34 AM
1badteg
May 17, 2007 08:06 PM
blakebrkr
Dec 15, 2006 04:54 PM
