b16a into 90 dx.....dpfi to mpfi question
Old Nov 27, 2003 | 01:20 PM
b16acrxer's Avatar
Default b16a into 90 dx.....dpfi to mpfi question
okay! on the dx motor harness that im putting on my 1gen b16a i cant find a sensor for a certain plug to go to: the eacv and the TA sensor have their plugs, but theres one more plug without a sensor the wires are orange and blk/yel. where does this go, do i just leave it unplugged. i was at truent's site and he wrote this about it:
Idle air control sensor [90-91 only?]
Cut the two wire sensor plug off of your old harness with orn and blk/yel wires, and connect to the idle air control sensor wires/plug on the new harness.
i have no idea. please help!
Old Nov 27, 2003 | 01:54 PM
dohcnotec's Avatar
Default Re: b16a into 90 dx.....dpfi to mpfi question (b16acrxer)
If you post the correct names for the sensors/Plugs, someone may be able to help
Old Nov 27, 2003 | 02:18 PM
1CiViC1's Avatar
When doing the dpfi to mpfi swap, you will have one left over plug off the harness...
Old Nov 27, 2003 | 03:38 PM
b16acrxer's Avatar
Default Re: (1CiViC1)
cool, i just wanna make sure that this one that ive got left over is supposed to be left over, cuz i havent seen that on any website...
Old Nov 27, 2003 | 11:58 PM
1CiViC1's Avatar
Default Re: (b16acrxer)
these are the left over plugs. 2 are from the dpfi injectors, and the other, which is the one you have left over, is for the tandem valve.
Old Nov 28, 2003 | 07:05 AM
b16acrxer's Avatar
the tandem valve is the one on the back of the dx manifold right? and it has orange wire and black/yellow wire running to it?
and i connect these wires to nothing when converting to mpfi correct?
Old Nov 28, 2003 | 08:08 AM
USDM 4G VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16acrxer &raquo;</TD></TR><TR><TD CLASS="quote">the tandem valve is the one on the back of the dx manifold right? and it has orange wire and black/yellow wire running to it?
and i connect these wires to nothing when converting to mpfi correct?</TD></TR></TABLE>
correct thats the left over plug...
Old Nov 28, 2003 | 10:04 PM
b16acrxer's Avatar
Default Re: (USDM 4G VTEC)
sweeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeet
almost done rewiring....now i just gotta do the 5 speed conversion....
Jap_Spec_Imports
Nov 22, 2007 11:33 AM
89D15CRXDX
Oct 25, 2006 03:05 PM
mymeatb18"
Jan 29, 2005 12:23 PM
Greg456
Mar 12, 2004 09:24 AM
NatedoggAZ
Nov 8, 2003 03:59 PM
