Which fuse to reset the ECU?
Old Nov 27, 2003 | 01:14 PM
2dark2bslow's Avatar
Default Fuses, fuses, so many fuses?
i am looking to reset the ecu but my car never came with thte fuse cover.
which is the ecu fuse?
gracias
Old Nov 27, 2003 | 02:47 PM
D's Avatar
D
Default Re: Fuses, fuses, so many fuses? (2dark2bslow)
7.5
Old Nov 27, 2003 | 03:56 PM
JjuuN R's Avatar
can't you just unplug your car battery and hook it back up to do this ?
Old Nov 27, 2003 | 05:43 PM
Default Re: Fuses, fuses, so many fuses? (D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D &raquo;</TD></TR><TR><TD CLASS="quote">7.5</TD></TR></TABLE>
well i just got back from drifving 20 minutes to find out there are about 12 7.5 fuses.
i thought of disconnecting the battery, but im not sure if that will reset the VAFC also?
Old Nov 27, 2003 | 05:58 PM
chad's Avatar
Moderator
under the hood it is the 15 correct? blue one in left upper corner...
Old Nov 27, 2003 | 08:03 PM
D's Avatar
D
Default Re: Fuses, fuses, so many fuses? (chad)
back up radio fuse is a 7.5
Old Nov 27, 2003 | 08:19 PM
milo's Avatar
isnt it the 7.5 next to the 15 amp fuse under the hood? thats what i remember.
Old Nov 27, 2003 | 08:45 PM
MARCO...
Old Nov 27, 2003 | 08:58 PM
JjuuN R's Avatar
damn a bunch of fuses :D
disconnect the negative battery cable, put it back on, and call it a day.
and your VAFC will keep it's current setup.
do most of you guys reset the ecu when the weather changes drastically?
luvinmyGSR
Jun 12, 2006 10:44 PM
gutterslide
Jun 3, 2005 09:44 PM
Pearlude
Nov 14, 2004 06:41 PM
trooper0641
Jan 2, 2004 10:09 PM
sleepyhamsterlx
Nov 26, 2003 06:52 PM
