a/c compressor
Old Nov 26, 2003 | 06:08 PM
Boostless-Lude's Avatar
Default a/c compressor
does anyone know if a h22's a/c compressor would work and fit on an h23 motor
Old Nov 26, 2003 | 06:46 PM
Cottonwoodz's Avatar
Default Re: a/c compressor (Boostless-Lude)
yes, just have to change pulley..
Old Nov 26, 2003 | 06:50 PM
Default Re: a/c compressor (Cottonwoodz)
when u say change the pulley what do u mean. Get an h22 one? And when i do that don't i have to change some other things (i'm not sure just because its vtec or something)
Old Nov 26, 2003 | 07:04 PM
PrecisionH23a's Avatar
Do you have to change the pulleys so you can run the same length h22a belt? I would think the belt groove patterns would be the same so if you wanted to couldn't you just find a different length belt to run?
4bidden's Avatar
The H22 belts have 1 more rib than the H23 belts, so you'd have to change the pulley. Replacing the pulley shouldnt require changing anything else. See what the difference in size is though.
Old Nov 26, 2003 | 07:15 PM
Default Re: a/c compressor (4bidden)
thankx
Old Nov 26, 2003 | 07:18 PM
biglew's Avatar
Why can't he just get a belt with 1 less rib then?
Old Nov 26, 2003 | 07:22 PM
4bidden's Avatar
Default Re: (biglew)
lol........just think about it man. Keep in mind that belt runs around the crank pulley, alternator, and AC.
Old Nov 26, 2003 | 07:26 PM
biglew's Avatar
Default Re: (4bidden)
Right, for some reason I was just thinking about ac straight to the crank pulley. My bust.
Ef4doorwagon
Jun 15, 2014 06:15 PM
zcmotor
Oct 1, 2013 08:15 PM
V8wannabe
May 6, 2010 12:56 PM
steven100100
Oct 9, 2008 11:17 AM
