can i weld these pipes with a mig welder
Old Nov 26, 2003 | 04:56 PM
Optiks.'s Avatar
Default can i weld these pipes with a mig welder
i want ot run them for ic pipes they are 2.5" and it says they are alluminized, can i mig weld these?
Old Nov 26, 2003 | 05:20 PM
Ri5e's Avatar
Default Re: can i weld these pipes with a mig welder (Optiks)
Looks like Aluminized Steel, Sure
Old Nov 26, 2003 | 05:27 PM
Howitt's Avatar
Default Re: can i weld these pipes with a mig welder (BG Boost)
sure can
Old Nov 26, 2003 | 06:36 PM
ScrapinSi's Avatar
yup
Old Nov 26, 2003 | 07:54 PM
BoostedH23a1's Avatar
Default Re: can i weld these pipes with a mig welder (ScrapinSi)
ill 4th that yup
Old Nov 29, 2003 | 08:32 AM
Optiks.'s Avatar
Default Re: can i weld these pipes with a mig welder (jz)
worth 40 bucks cdn for 2 of those and a 2.5-3" expansion for the tb?
Old Nov 29, 2003 | 09:50 AM
RedlinedVTEC's Avatar
Yup definately worth $40 for two of those bends... where you getting them or is a private seller?
Optiks.'s Avatar
Default Re: can i weld these pipes with a mig welder (RedlinedVTEC)
a local here is turboing is corolla but decided to go with 2" instead of 2.5
Old Nov 29, 2003 | 12:06 PM
92 hatch's Avatar
I use the same stuff 16 gauge with a aluminized coating on it for custom exhaust work.I most of the time tig mine but sometimes mig it.Always grind it as said before but I also keep some ceremic spray to paint over the welds after I am done to keep it from rusting.Just a thought.
Old Dec 2, 2003 | 10:45 PM
jdmeg6er's Avatar
hey, i was just wondering does the mig welder have to be a certain amount of amps to weld it or will any mig welder work
Old Dec 3, 2003 | 02:39 PM
xtal's Avatar
Default Re: can i weld these pipes with a mig welder (woodai)
Pipes will weld with anything, I do similar stuff all the time with my little mig. Just do small pieces at a time.
Old Dec 3, 2003 | 02:57 PM
stierhund's Avatar
any amp draw will work, but a mig welder designed to run off low voltage has to pull more amps to be effective, its better to use a 220v mig because it actually draws less amps, but more effectively
skill has everything to do w/that tho
(usually twice the voltage is half the amp draw, and a 220v mig will draw more than what it should)
9TechNine9
Welding / Fabrication
Apr 6, 2018 05:14 PM
EF9_TryMe
10
Sep 11, 2012 09:48 AM
Muckman
10
Apr 3, 2006 06:57 AM
joshcivic00
Jul 19, 2005 08:20 PM
evoeone
Jun 6, 2003 06:26 PM
