I think its the coil.
Old Sep 15, 2001 | 12:09 AM
FaTBastarDinaCiviC's Avatar
New User
Default I think its the coil.
My girls got a 95 automatic dx right. I took her car to the store and it cut off. No loss of power, radio and everything still comes on, it cranks but it won't turn over. I pretty sure its not the battery, i have yet to test it though. I just changed the alternator so i know its not that. Now ive changed the coil on this thing twice so far and its done the samething everytime it went bad. I got a check engine light and a battery light when it happened. Now ever since i changed her timing belt its been slightly off but not enough to tear it up (just no real speed, been meaning to correct that). Anybody with a clue, please?
Old Sep 16, 2001 | 08:26 AM
clockworks's Avatar
Default Re: I think its the coil. (FaTBastarDinaCiviC)
What did the check engine code read?
Old Sep 16, 2001 | 09:49 PM
flymecourageously's Avatar
New User
could be the starter,check the connections
Old Sep 17, 2001 | 09:58 AM
bigTom's Avatar
Default Re: I think its the coil. (flymecourageously)
the starter would cause the car not to crank... so it cant be that if it cranking... id check the wiring as well make sure everything is plugged in and in connected where it needs to be...
Old Sep 17, 2001 | 02:25 PM
fixhondas's Avatar
Coils burn out for a reason- if you replaced your TEC Honda coil with an aftermarket piece of **** (usually Italian) it will burn out just because it is a piece of trash. Now, your honda coil burned out most likely because there is excessive resistance in the secondary circuit (plugs, cap, rotor, possibly wires). As resistance increases (ie: spark gap wears) the trigger voltage also increases. As more voltage is needed to cross the larger gap- more current is needed to create that voltage. This eventually overheats the coil and burns it out. If you haven't already- throw a new HONDA cap-rotor- and plugs on it- get some honda or NGK wires if you have replaced the original wires with some junk aftermarket crap, and go buy a HONDA coil. To be sure it is the coil- while cranking, check for pulsing ground at the negative terminal of the coil. If there is no pulse then your igniter is hosed (a common problem with OKI igniters).
Old Sep 18, 2001 | 02:16 AM
New User
Figured it out her timing belt split. Everything seems fine, thanks for the info fellas. As far as the coil goes that explains why i've changed it twice already.
[Modified by FaTBastarDinaCiviC, 6:17 AM 9/18/2001]
Old Sep 18, 2001 | 04:50 PM
9integra2's Avatar
New User
Her timing belt split, you cranked the engine over in hopes of it starting, and nothing is damaged? Does that sound like a miracle to anyone else? I know when something similar happened to me, all valves were bent.
[Modified by 9integra2, 1:52 AM 9/19/2001]
Old Sep 18, 2001 | 09:28 PM
New User
Default Re: I think its the coil. (9integra2)
[QUOTE]Her timing belt split, you cranked the engine over in hopes of it starting, and nothing is damaged? Does that sound like a miracle to anyone else? I know when something similar happened to me, all valves were bent.
Naw everything was okay i took the entire engine apart today to make sure, thank God!
hondazallday
Jan 8, 2014 09:44 PM
SwagNationEK9
Dec 2, 2013 04:22 PM
dw31
Jun 4, 2013 08:40 AM
PatrickGSR94
Aug 8, 2008 09:44 AM
crazy_ugly_coyote
Jul 28, 2006 03:19 AM
